Mainsheet line and tackle. - Page 3 - SailNet Community
post #21 of 31 Old 05-04-2009
Personally, I prefer to have a bit extra safety margin on the highly loaded controls, like the mainsheet... if you've never seen a block disintegrate under too high a load and shoot pieces past your head... you don't know why I do this... but I'd recommend going with the 57 mm blocks..
Originally Posted by zz4gta View Post
I think I may opt for the 40mm although that may be pushing the standard working load a bit.
sailingdog is offline
post #22 of 31 Old 05-04-2009
blt2ski's Avatar
Here is what Harken recomends, assuming you have the loops at the bottom of your boom. If you have webbing holding the boom sheaves, then a different sheave is needed. They recomended 40's for the whole thing. I have 57's for the main, and 40's for the micro per their recomendation on the compuspec.
Your boat Name:
Your boat Type: Merit 25
Quantity Part Number Description Catalog Page No.
Mainsheet System 3A -- Gross Trim
1
.059
Little Fiddle Hexaratchet w/Cam
67
2
2636
40mm Carbo Block
49
Mainsheet System 3A -- Fine Tune
1
2655
40mm Carbo Fiddle
50
1
2658
40mm Carbo Fiddle w/Cam Cleat & Becket
50
2
071
Stand Up Spring
101
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #23 of 31 Old 05-14-2009
blt2ski's Avatar
ZZ,
Here is a pic with the micro on it. Not sure if you have done anything as of yet.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #24 of 31 Old 05-15-2009 Thread Starter
I don't discuss my member
zz4gta's Avatar
Thanks marty. I'd like to do something like that, I bought the 40mm carbo blocks and ran some 5/16th Samson Apex single braid through it. If it actually measured 5/16th in diameter than it would run fine, but it looks closer to 3/8th, this apex stuff must run really large, and therefore drags through the cam cleat and little hoop. I'm thinking of filing the hoop/fairlead to make it a little bigger.
Or I could just buy a 1/4" mainsheet which is what the 40mm carbos claim is their max line size.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #25 of 31 Old 05-15-2009
Last I checked, the 40 mm Carbo Harken blocks have a max line size of 3/8".
post #26 of 31 Old 05-15-2009
tommays's Avatar
I have worn out a few full size parts and find they keep things pretty close to the edge
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #27 of 31 Old 05-15-2009
That's what I was thinking. I'm hoping with the new blocks and line I'll be able to reduce some friction to make it a little easier (one arming it). Any suggestion on line?
If you keep that one arming up you will go blind. And for a guy who says he doesn't talk about his member you seem to be quite open about it.
freddyray is offline
post #28 of 31 Old 05-15-2009
blt2ski's Avatar
zz,
I would NOT file anything, but going to a smaller diam line would be better in the end. Otherwise, "IF AND WHEN" you do go smaller in line, you cam cleats may not close on the line. I have 1/4" in my 40mm micro setup, and it works quite nicely. Not sure I would want to go bigger in all honesty.
I have 1/2 or 9/16 in the 57mm main part.
I was at a lewmar winch maintenance class at local WM the other night, and he asked if we thought we needed new winches. The rep mentioned, "most" folks that feel they new new winches, are running line that is TOO large for the sheaves they have. Take the diam of the rope, multiply by 7, and that is the sheave size you need. As I am typing this, I am also thinking I am not quite right, but in the ball park for the ratio etc. just something to think about re the 40 mm sheaves, max line would be 6mm or 1/4" lline!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #29 of 31 Old 05-15-2009
Traditionally, sheaves are supposed to be eight times the diameter of the lines running in them. That has changed a bit with modern materials...some for the better, others for the worse.
post #30 of 31 Old 05-17-2009 Thread Starter
zz4gta's Avatar
The carbo fiddles will fit 3/8" line, and have a max line size of 3/8", however, the cam cleat Harken uses is only 1/4". They also reduce the SWL to 400 and something pounds b/c that's what the cam cleat can hold. The cam cleat is the weak link in the system, and the tiny fairlead doesn't help.
I wouldn't mind going to 1/4" mainsheet, but I think it would be a bit of a pain to get a grip on it. I'm using 5/16" apex and it measures closer to 3/8". The 3/8" apex I originally bought measured in at 1/2". Either they have a new guy working the rigging shop at Defender, or Apex runs REALLY big.
zz4gta is offline
Controlling Lines—Cleats, Clutches and Jammers sailingdog Gear & Maintenance 7 04-30-2009 07:19 PM
Could you do COB recovery by yourself? davidpm General Discussion (sailing related) 77 04-17-2009 08:50 PM
Fishing Under Sail Don Casey Her Sailnet Articles 0 04-18-2002 08:00 PM
Mainsheet Systems Dan Dickison Gear and Maintenance Articles 0 10-22-2001 08:00 PM
Setting Up Reefing Tackle Dan Dickison Seamanship Articles 0 01-11-2001 07:00 PM
