Old 04-30-2009
JudyWakefield is on a distinguished road
1983 Bayfield 25, Yanmar 7.5Diesel
I am in a dilemma. Have had my boat only since Sept. 2008. Have had it winterized since Nov. and may not be able to sail it this summer. Am I better off leaving it winterized until next summer? Can I damage anything?I have even thought about selling her but dont really want to.
I am worried mostly about the engine. Should I do anything extra to it for this extended period of time? I live in the cold north ( Nova Scotia, Canada ). Will appreciate all comments and advice. Thank you.
Old 04-30-2009
JohnRPollard's Avatar
Moderator
Judy,
My suggestion is that you leave the boat fully winterized until you know for certain that you can use it this summer. If it turns out that you can't use it, you should be fine leaving everything as is.
This assumes that you fully winterized the engine, added fuel stabilizer, loosened belts, plugged exhaust outlet, etc. Also, it would be wise to charge the batteries every 2-4 months or so (depending whether wet cell or AGM), so that they do not go completely flat. Consider ventilating the boat from time to time, too.
Hopefully you can keep the boat and enjoy her again someday. Good luck!
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Beneteau vs. Yanmar – Green vs. Red Cooling Fluid Swesail Gear & Maintenance 37 04-14-2009 12:32 PM
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
1983 Yanmar 1GM engine -- Oil for Gear Case H216Sailor Gear & Maintenance 11 04-05-2008 09:56 PM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
