Old 04-30-2009
kmdudley7 is on a distinguished road
marine a/c water pump size??
hello all, While I was cleaning boat nooks and crannys out preparing for some coastal cruising this summer, I came upon an Eastern marine 6500 btu a/c unit. Found it under the v berth behind the water heater unit. Bout had a cow from excitement As i have been pricing a/c units lately. 1200-1500 bucks. well took it home hooked the water hose to in plugged it in and BRRRRRRR blowing good cold air.. We can sure use it in August on the south gulf coast.. Already has the intake thru hull for pcooling pump, and a discharge sea **** is readily available. as far as the coil condensation, Will probably just run it to the bilge . Bilge pump can pump out as needed. Question is.. It didnt have a shurflo, etc. type water pump in boat. So what size GPM should I use for a/c unit?? 320 600 900 or?????? For cooling condensor??? any help always appriciated.. It is a Eastern Marine 6500 BTU cannot find info on that model. Think Eastern went out of biz..
Thanks
Mark and Karen
Old 04-30-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Look up Depco pump. They will know what you need and take good care of you
Depco Pump Company
Old 05-01-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
Capacity is not critical. 300gph (or higher) should be fine. Don't run it to the bilge!! That's a lot of water and if you leave the AC running and leave the boat for a period the bilge pump malfunctions, your boat will fill pretty quickly. Note that most AC pumps are 110VAC, not 12VDC since they are used only in a slip on shore power.
Old 05-01-2009
Hey there Jimscal.. Dont get me wrong. I will run the cooling water thru the hull BUT the condensation pan water drip down to the bilge. The pan water will be very nominal.. Thanks Tractor supply has a pump for about 80 bucks a/c current..
Tartan / C&C issues MarkSchu General Discussion (sailing related) 228 01-19-2009 01:31 AM
2GM20F - Fresh Water Circulating pump Bill R Island Packet 5 09-17-2007 12:53 PM
Water Pump tdw Gear & Maintenance 8 05-21-2007 05:27 AM
Winter Storms and Hypothermia Michael Carr Her Sailnet Articles 0 02-26-2004 07:00 PM
Marine Radios Overview Jim Sexton Gear and Maintenance Articles 0 09-30-1999 08:00 PM
