05-05-2009
Stainless steel is just that, it stains less... not stain free... It does corrode, especially when in close proximity to aluminum, where the aluminum corrodes, due to the galvanic differences in the metals, and effectively bonds itself to the stainless steel. Heat, PBlaster, and cold often can work to break the corrosion induced bond.
Originally Posted by L124C
I was recently removing several small stainless screws. Some came out without a problem. Some required my impact diver and some were corroded (Stainless?) to the point that a screwdriver of any type, would no longer work. I tried an Easy Out, and a gizzmo called a "grabber". The stainless laughed at both! I recalled an old trick and grabbed my Dremel. Using a fine cutting wheel, I created a new slot and easily removed the screws with a flat screwdriver! In comparison with the other methods it was so easy and effective it was actually shocking, probably took 30 seconds! I did a search and didn't see it mentioned so i thought I would share it.
