Old 05-05-2009
AdamLein's Avatar
AdamLein will become famous soon enough
Stainless steel anchors
Okay hold on a second. I keep reading about how stainless steel is unsuitable for use below the waterline. So how come I see so many stainless anchors?
s/v Essorant
1972 Catalina 27
Old 05-05-2009
camaraderie's Avatar
moderate?
Because people are foolish...and the boats with stainless anchors have dock spaces and don't sit for weeks with the anchors on the bottom in the mud.
Old 05-05-2009
tager's Avatar
tager is on a distinguished road
Because corrosion doesn't vaporize steel as soon as marketing people would like you to think! And because people have disposable income to spend on shiny things.
Old 05-05-2009
Because they're really pretty...and shiny... and the people who own them are more like raccoons than sailors... and they want pretty, but not very functional anchors.
Stainless steel, when submersed in mud, sand, etc, is going to suffer from oxygen deprivation, crevice corrosion, and other issues. It is going to get scratched up, and suffer from corrosion where ever the finish is marred... and one day, with little or no warning, the anchor's stock or some other important bit is going to snap under load and put your boat up on the rocks...
As Cam points out, the majority of boats that have stainless steel anchors are marina queens, and rarely anchor out, if at all.
Old 05-05-2009
Sea Slacker
brak is on a distinguished road
hmm, so if stainles is so poor under these conditions what about aluminum?
Old 05-05-2009
AdamLein's Avatar
Okay! I thought as much, and yet they seem so ubiquitously marketed, even by respectable manufacturers like Manson and Rocna. Good to know.
s/v Essorant
1972 Catalina 27
Old 05-05-2009
AdamLein's Avatar
My guess is that aluminum is considered too light... my current anchor is a fairly large but aluminum fluke, and it's surprisingly tricky to set. Also I wouldn't trust it under heavy load, especially after a wind shift; if it holds, the torque would probably bend the shank.
s/v Essorant
1972 Catalina 27
Old 05-05-2009
tager's Avatar
I would get a forfjord anchor if I was in the market. Currently have a danforth from the PO. I also think anchors should be on cables, not chain, but I am crazy.
Old 05-05-2009
It is too light to set well in many conditions... it is also not as strong as a steel anchor in many cases, and can fail if the load is applied to the anchor from the wrong direction.
Old 05-05-2009
Sea Slacker
I use aliminum Fortress and have no issues with it setting. I do wonder about corrosion though.
Stainless Steel... merttan Gear & Maintenance 14 04-12-2008 07:59 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 05:02 AM
Using Two Anchors Tom Wood Seamanship Articles 0 01-19-2004 07:00 PM
Using Two Anchors Tom Wood Gear and Maintenance Articles 0 01-19-2004 07:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
