looking for a chain scrubbing brush - Page 2 - SailNet Community
post #11 of 13 Old 05-13-2009
saildork's Avatar
Lin, you might have to make one such as Sailingdog just described, which incidentally, is discussed in Don Casey's '100 fast & easy boat improvements' on page 45. I'm sure you've seen many variations on this theme as well. If you find one that's commercially available, please share it on this forum.
Sailing isn't a matter of life and death. It's much more important than that!
saildork is offline
post #12 of 13 Old 11-27-2013
Re: looking for a chain scrubbing brush
post
vpo3 is offline
post #13 of 13 Old 12-29-2013
past Caribbean cruiser
While cruising the Caribbean, I created a chain scrubber that I think works well. Using a 12" piece of 4" PVC pipe, split lengthwise. A piece of rubber sheeting as a hinge on one side, bolts protruding on the other side with a piece of shock cord for closing the opening side. Inside, I attached four small kitchen scrub brushes. An 8 lb dive weight is hung from bottom side by a rope that is attached to scrubber and extends upward for a bout 15 ft. The devise is opened and then closed over the chain, the line is ties to the bow rail and the scrubber is lowered into the water over the chain, submerged by several feet. As you raise the anchor the scrubber cleans the chain and it is flushed by the see for the several feet it is submerged. It removes most of the soft group and mud that accumulates with longer anchoring times. This works well for 3/8" chain, modifications would be needed for other chain sizes.
DocTom54 is offline
To Have and To Hold (anchoring) GoodOldBoat Good Old Boat 7 05-23-2015 06:38 PM
The Perfect Anchor Rode Tom Wood Seamanship Articles 0 09-08-2003 08:00 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 08:00 PM
Dueling Rodes Tom Wood Seamanship Articles 0 10-21-1999 08:00 PM
Dueling Rodes Tom Wood Gear and Maintenance Articles 0 10-21-1999 08:00 PM
