Clevis pin on top of forestay - Page 2 - SailNet Community
post #11 of 13 Old 05-07-2009
pdqaltair's Avatar
There isn't room for much in there...
Originally Posted by pdqaltair View Post
How close is close?
One the other hand, the pin ain't falling out.
One way to get more space would be to go with high-tech line, which I am considering. As you can see, the spin halyard is moving around in the same space.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #12 of 13 Old 05-07-2009 Thread Starter
Sea Slacker
that's a tight fit. I think my mast actually provides enough clearance that chafing may not be so bad (but on the other hand should anything happen to the cotter pin, clevis pin certainly has more than enough space to back out and go AWOL)
brak is offline
post #13 of 13 Old 05-07-2009
pdqaltair's Avatar
An example of a good surveyor.
He looked at everything and took MANY photos. Removed every panel on the boat that had wire behind it.
It was worth the money. Even though I would have eventually seen things like this, he brought thing to light that might have gone unseen for years.
Hard dodger GoodOldBoat Good Old Boat 15 03-21-2013 01:20 PM
Furler - Replacing and new installation artbyjody Gear & Maintenance 5 08-18-2008 05:22 PM
Correct forestay diameter? wysiwyg Gear & Maintenance 8 04-15-2007 06:02 PM
Top 10 Sailing Venues Dan Dickison Cruising Articles 0 08-11-2002 08:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
