Engine rpms fluctuating - Page 2 - SailNet Community
post #11 of 14 Old 05-09-2009
scurvy dog
delan's Avatar
You may also check the ground to the guages, if it's corroded or unattached, the voltmeter will find ground via the engine sensors, intermittently.
Check all the grounds.
delan is offline
post #12 of 14 Old 05-11-2009 Thread Starter
Vikingsailor
c40eb's Avatar
Update #2
Well, brought the alternator into Ron's Auto Electric in Windsor, ME. Ron stuck it on the big testing machine and confirmed there is something up with the regulator. It's "bouncing"...meaning, the output is fluctuating.
He's gonna pull it apart and check out the regulator.
So...seems I'm on the right track.
Thanks again to all for the input.
It's not whether you're paranoid...it's whether you're paranoid enough.
s/v Cloudman
1988 Sabre 30
c40eb is offline
post #13 of 14 Old 05-15-2009 Thread Starter
Vikingsailor
c40eb's Avatar
Update #3 (FINAL!)
Well, picked up the alternator today. Ron said someone previously had decided to paint various parts of the alt. Parts they shouldn't have. Interior surfaces that should be bare to make a good ground were painted.
He cleaned it, tested it and all is good.
I just reinstalled it, cranked up the engine, and all looks great! Gauges steady and volts where they should be. The regulator is regulating correctly.
So...now just a matter of finishing the cleaning & waxing and getting in the water. Hope by end of next week.
Thanks to all who replied! Much appreciated.
s/v Cloudman
1988 Sabre 30
c40eb is offline
post #14 of 14 Old 05-16-2009
snake charmer, cat herder
zeehag's Avatar
goood to hear ya got the problem fixed----
zeehag is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 09:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 09:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 09:00 PM
