3M 4200 or 101 - Page 2 - SailNet Community
post #11 of 13 Old 05-10-2009
Maine Sail's Avatar
Originally Posted by Pub911 View Post
as long as we're into it...where does 4000 fit in to the product line?
It's neither a polyurethane nor a polysulfide but rather a polyether. It's supposedly more UV resistant but in my own experience it does yellow.
It has a similar general rated bond strength to 4200 at 300 PSI.. However it bonds to gelcoat at about 424 PSI. At 500 hours it has an elongation before break of 804% but at 1000 hours it drops back to 723 which tends to mirror polyurethane products losing flexibility over time..
It would not be my first choice for below water use..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 13 Old 05-10-2009
Probably, but if you go with 4200, you can wait until it is mostly or fully cured..
Originally Posted by T37Chef View Post
Can the boat be splashed before the 2-3 week cure time?
sailingdog is offline
post #13 of 13 Old 05-10-2009
jarcher's Avatar
It says on the packing that it is safe for "most plastics." I suppose the only way to know for a particular plastic is to try it?
Also, when it bonds to gel coat at 500 psi, does this mean its stronger than the gel and should be considered permanent?
jarcher is offline
3m 5200 NOLAsailing Gear & Maintenance 20 03-18-2009 07:48 AM
How do I remove 4200 from Lexan? kaakre Gear & Maintenance 12 07-21-2008 11:43 AM
Favorite sealant for bedding deck hardware lharmon Gear & Maintenance 28 04-14-2008 11:14 AM
Dehler Optima 101 boatmonkey General Discussion (sailing related) 2 08-31-2007 09:39 AM
At rally, calls for allowing 101 Haitian migrants to stay - Miami Herald NewsReader News Feeds 0 04-01-2007 02:15 AM
