Old 05-09-2009
SeaDeucer is on a distinguished road
Oversized cutlass bearing
Now that we have replaced the coupler, stuffing box, and shaft from metric to imperial, we discovered the new cutlass beariing extends beyond the strut by almost 1/4" on each side-after the marine service parts place closed. Apart from installing the batteries, she is ready to launch Is this a (big) problem? Should we wait and have it cut to size? I was a bit mifffed as they had the original and have to shave some off the outside diameter to match the original, how could they miss the length? It is quite snug in the strut. All replies greatly appreciated, (this is the copper rubber one). She is as expensive as she is pretty awesome looking this Jeanneau.
Old 05-09-2009
PalmettoSailor will become famous soon enough
I know several folks that have become frustrated trying to change their cutlass bearing and simply cut off whatever portion was sticking out with a hacksaw. If the propshaft isn't in place you could push the bearing flush on one end so you just make one cut to remove the extra 1/2", but since you didn't mention that I assume you'll have to make 2 cuts. Just be careful to only cut through the metal part. You can cut the rubber part with a razor or sharp knife so you don't damage the propshaft.
There is also the option of just leaving it as is if the 1/4" at each end doesn't affect anything else. The only issue I see would be making sure you don't get marine growth on it. That seems to be what your Boatyard was going to do. I can't really see where a bit of extra bearing surface is going to hurt anything.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Old 05-09-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
The bearings only come in a few standard lengths. As midlifesailor said, just cut it to length with a hacksaw.
Old 05-09-2009
fullkeel7 is on a distinguished road
Uhhh...I've never changed a cutless bearing so I can't really comment. I have looked closely at other's struts and was wondering why a little excess in length of the bearing on either side of the strut would necessitate trimming? With the exception of an interference issue, would a little extra support be a bad thing? Just for my future reference...Inquiring minds wanna know. Thanks.
Old 05-09-2009
cnc33voodoo's Avatar
cap'n chronic
cnc33voodoo is on a distinguished road
I changed my cutlass bearing 2 weeks ago and had the same issue.
They come in standard lengths.Buy a sharp new hacksaw blade and cut the end off as jimsCAL mentioned.Very easy.
c&c 33 tall rig
Old 05-09-2009
delan's Avatar
scurvy dog
delan is on a distinguished road
It won't hurt anything, in fact it will last a little longer, but it looks funny.
I'd cut it off.
Replacing A Cutlass Bearing (Photo Heavy) Maine Sail Gear & Maintenance 8 12-19-2009 07:33 PM
Max weight of shat/prop on cutlass bearing kaakre Gear & Maintenance 1 05-30-2008 06:31 PM
PS 37 Cutlass Bearing waypt1 Pacific Seacraft 5 01-15-2008 03:03 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
