05-14-2009
I used a good normal spray paint mask with paint pre-filters
BUT in the room were i painted there is a 1000 CFM fume hood and i allways work on one side of the mast and rotate it with the hood pulling the FUMES AWAY from me at ALL TIMES
As i wear glasses the full face is a PITA BUT is safer
At this point HVLP guns are the best becasue they have the best transfer rate (puts the paint on your boat not in the AIR ) and I like SATA
As far as the different paints you dealing with a good paint or a good paint with the real change you might be able to do repiars better
BUT go to any body shop and try and get 1/2 a door painted its NOT gonna happen and look good  no matter what they do to the paint
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
