IMHP Perfection is the consumer line of paint and Awgrip is the pro line and when its all said and done there is no BIG difference
I went with Perfection because it has a BETTER system to prime Alu parts like a mast .
The Awgrip uses and acid wash system that requires a lot of rinsing with water which is a big problem in MY CASE and i think in painting masts in general as it is a PITA to get a mast dry enough for the next step after you hose it down because of all the places that trap water
I sprayed with a SATA mini jet with a 1mm tip which is a really good size for things like masts because of the small fan size really cuts down on over spray
I thinned the paint 10% buy volume after waiting the 15 minutes when mixing the A and B , YOU NEED really good containers with volume marks i used lab 500,150 and 50 ml lab glass ware which has Volume markings
We found that 50 PSI at the wall mount filter system with a 35' hose gave good atomization to lay down a smooth coat the tip was pretty much WIDE OPEN
Again the real issue with spraying is the
two hour pot life because the best practice is to do ALL the paint in ONE session and buy the time your ready for a second coat the paint is past its pot life and NO GOOD
So you have to have a good plan in place and it takes about ONE MONTH for the paint to get COMPLEATLY DRY
Yea it looks pretty good after a week BUT its a month for a FULL cure
