Old 05-12-2009
drewb8s is on a distinguished road
DRS Sail?
What is a DRS sail and what is it used for?
Old 05-12-2009
patrickrea's Avatar
patrickrea is on a distinguished road
Drifting, Reaching Spinnaker. Used for light wind and reaching. Basically its's an assymetrical.
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
Old 05-12-2009
an assymetrical? what does that mean? so basically a DRS is a spinnaker right or is it a specific kind of spinnaker? Does anyone have a link where i can see a DRS?
Old 05-13-2009
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Google "drs sail". You will get several hits that are appropriate.
It's basically a cruising chute.
Hey, can one of you guys pass me a crab?
Old 05-14-2009
patrickrea's Avatar
Basically it behaves like a really big light genoa. A regular spinnaker has both side edges identical, uses a pole to get the sail outboard and is attached only at the top and then has sheets and guys to control the rotation of the sail around the front of the boat and to trim the sail. A symmetrical spinnaker requires constant trimming to maintain shape and is efficient from a beam reach down to a dead run.
A DRS or assymetrical has a short side between the head and what becomes the tack. A sheet to control sail trim is attached to the clew and the tack is attached by a strop or short line to a bow fitting. It trims like a genoa and doesn't need a lot of tweaking to get good results which is why it is popular with cruisers.It is very efficient from a close reach down to just below a beam reach.
Patrick Rea
Heavy weather sailing sailorfrank Learning to Sail 18 08-24-2009 01:24 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
What is the point of a traveller? dwbecker Learning to Sail 9 09-25-2006 08:35 PM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
First Sail of the Season Bruce Caldwell Seamanship Articles 0 06-05-2003 08:00 PM
