Microns.. how low do you go? - Page 2 - SailNet Community
post #11 of 17 Old 05-12-2009
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Originally Posted by celenoglu View Post
HP is not important, nearly all diese engines use very similiar injectors that have nearly the same tubing for diesel passage.
I understand your point, but HP is very important, as will determine the diesel flow through the filter, so it's area and granular filtering. A trusted dealer should be knowledgeable to indicate what filtering system is more appropriated to your engine (size, rpm, temp, etc ...)
Nave Rara
Beneteau Oceanis 43
negrini is offline
post #12 of 17 Old 05-13-2009
blt2ski's Avatar
I just put a Racor on my boat for the first filter, IIRC it is a 10 or 20 micron, then the one on the motor is a 2 micron! This is how I understand,, and I operate with my (5)diesels for the ones with 2 inline filters.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #13 of 17 Old 05-13-2009
Old Fart
DwayneSpeer's Avatar
Beta engines
A few years back I repowered with a Beta. At the time I was going to be very conservative and began to use 2 micron filters in my prefilter. After going thru 4 filters during a short trip up the Washington coast and ending up at midnight with no engine (clogged filter) and heavy seas, I asked Beta what they recommended. They use a 10 micron filter on their engine and recommend either a 10 or 30 micron prefilter. I now use a 10 AND prefilter the fuel in my tank with a fuel conditioner before any significant trips. The fuel conditioner is one I built using a top fuel dragster fuel pump (plenty of flow rate) and HUGE inline filter.
Hey, can one of you guys pass me a crab?
DwayneSpeer is offline
post #14 of 17 Old 05-15-2009 Thread Starter
One of None
deniseO30's Avatar
Wow... turns out there is a 2m element for my #220 series filter. so now i'm torn on which to get the. R24T is 10m and R24S is 2m. The small spin on for the engine is only 10m. New tank is in and the engine is running again on clean fresh fuel!
My last project!
deniseO30 is offline
post #15 of 17 Old 05-15-2009
NEVER keep the tank full!!!! Especially if you only use a few gallons a year. A full tank means that the fuel is much older and has sat around growing microbes longer. It is fiction that condensation adds water to a diesel tank. If there is water in your tank it came from dirty fuel or a bad O-ring or some simular defect. Physics make it impossible for condensation to add a significant amount of water to a diesel tank. The Myth of Condensation in Fuel Tanks by David Pascoe: Boat Maintenance, Repairs and Troubleshooting
MoonSailer is offline
post #16 of 17 Old 05-16-2009 Thread Starter
One of None
deniseO30's Avatar
haven't changed filters yet but my engine is most definitely running smoother! I"m guessing it has better fuel pressure since the pick strainer on the old tank was so badly gunked up.
My last project!
post #17 of 17 Old 05-17-2009
I guess the key word here is significant. Any amount added is not good no matter what the "experts" say here on the internet.
lancelot9898 is offline
Low Oil Pressure buzzer/alarm sapadeni Gear & Maintenance 31 02-15-2014 02:56 AM
Oil leak - Low level Westerbeke 27 swanfrogg Gear & Maintenance 2 11-05-2008 04:59 AM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
sitting on keel at low tide barefootsailing General Discussion (sailing related) 5 08-05-2003 08:21 AM
