Old 05-14-2009
sailhog has a spectacular aura about sailhog has a spectacular aura about
Twist in the forestay...
A friend of mine has a bit of a twist in his forestay near the masthead on his Catalina 34. Does this look like it needs to be replaced, or can he leave it alone? He's been having trouble with his roller furler, which is probably what caused the problem. Any thoughts?
Here it is:
Old 05-14-2009
tommays's Avatar
That is well beyond FUBAR and ready to break
I had one upper shroud that was 1/4 that bad last year and you could never tune the mast right
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 05-14-2009
that looks like the result of a halyard wrap...and it needs to be replaced ASAP IMHO.
Old 05-14-2009
bob77903's Avatar
Tartan 41
bob77903 is on a distinguished road
A bit of a twist, just a tad of an understatement....holy cow, replacing it ASAP might not be soon enough...IMMEDIATELY....I wouldn't untie the dock lines with that forestay..tell your friend NOW, unless you don't like him
Old 05-14-2009
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Sailing Dog is correct. That's definately the sign of a halyard wrap and likely the furling line having been led to a winch. Ouch!!
The forestay needs be replaced and a halyard guide needs be added to the front of the mast so that there is a least a 10 Degree angle between the alignment of the halyard and the centerline of the forestay when your pal's largest headsail is at full hoist. With shorter luffed sails he can use a luff pendent at the head of the sail to get the top furling drum to full hoist.
FWIW...
Old 05-14-2009
eolon is on a distinguished road
Throw it away and get a new one. Also, your halyard is nearing the end of its useful life...
Best Regards,
e
Old 05-14-2009
I'd point out that the clevis pin for the toggle at the top of the forestay, in the masthead casting, is also a bit too long.
Old 05-14-2009
sailortjk1's Avatar
Now that that is over, how ya been you dirty Pig?!
I though "Twist in the Forstay" was really "My $%^s are stuck in my #$%"
Courtney is My Hero
Old 05-14-2009
Thanks for the replies, gents...
So if I'm hearing you all correctly, you're saying that he should leave it alone and that everything should be just fine. I'll pass this along... Thanks again!
TJK, you filthy dog! I'm fine... a buddy of mine came here from Boulder and we sailed our arses off for a full week. Two days after he left, I still had the sensation I was on the boat. Everything was moving... When will you be passing through next? Git yer keester down here, cap'n...
Old 05-14-2009
sailortjk1's Avatar
Ha, the dreaded "NO" motion sickness.
In the shower is where it usually gets me.
Julie is down in Jax as we speak. We will have to work on it.
Courtney is My Hero
Proper use of the Traveler PDixon Boat Review and Purchase Forum 12 01-02-2008 02:29 AM
Correct forestay diameter? wysiwyg Gear & Maintenance 8 04-15-2007 06:02 PM
what''s up with sail twist? hrae Learning to Sail 15 09-08-2004 03:00 PM
Depowering the sails and twist jbr Learning to Sail 22 02-21-2003 09:23 PM
Mainsail Twist for Waves Dobbs Davis Racing Articles 0 03-23-2001 07:00 PM
