05-14-2009
See if you can survey some Iroquois owners. Much depends on the lay-up...
Originally Posted by LookingForCruiser
Hi all,
I have recently purchased a 1969 Iroquois MkII catamaran, it should be showing up at the boatyard in Massachusetts early next week.
Now, the boat has no blisters, but I believe it has been in freshwater (Lake Huron) for most of its 40 years.
I'm nervous of what might happen when she's splashed into the saltwater after a season (or two or three), as blistering is much more prevalent in saltwater and this is a fairly old hull.
So, my question is, does it make sense to do a preemptive barrier coat? Or should I wait and worry about blistering if/when it happens?
and the resins used. If it was a Gemini, it would be at very high risk. If it were a Stiletto it would be at no risk. You made to troll British sites.
But SD is dead on if you can't get good info. If the hull is dry, you do have to strip it, but after that it's easy.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
