Old 05-15-2009
freddyray is on a distinguished road
moving the main sheet
and possibly adding a traveller. The main sheet on my boat is attached to the floor. I would like to move it back to the back deck and also possibly put in a traveller, but with my set up I cannot see where I can do that without interferring with the tiller. Any ideas or am I just stuck with what I have?
Old 05-15-2009
The only way to move it to the back deck would be to split it...so the mainsheet is connected to both sides, and forms an inverted-v over the tiller.
Old 05-15-2009
might just leave it then. Just learning and trying to get a bit more sail adjustment besides just the main sheet so thought a traveller might work well. I suppose if my traveller was above the tiller it might work. Might also be trying to make a silk purse out of a sows ear.
Old 05-15-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
A traveller is going to be tough. Only place would be in front of the tiller across the cockpit. One way the rig the mainsheet to the back deck is the use two blocks, one on the port side and one on the starboard and run the sheet from one side, to the boom, to the other side, and back again.
O"day 28 main sheet FourSeasMilford O'Day 2 09-11-2009 09:13 PM
O'Day 28 Main sheet arrangement FourSeasMilford Gear & Maintenance 9 03-08-2009 10:42 PM
okay main sheet to boom relocation scottyt Gear & Maintenance 15 03-01-2009 09:21 PM
BV and Main Sheet Block DrB Gear & Maintenance 7 08-27-2007 11:52 AM
Reading Flow and Making Adjustments Tom Wood Gear and Maintenance Articles 0 09-23-1999 08:00 PM
