Seacock Leaking - Page 2 - SailNet Community
post #11 of 12 Old 05-22-2009
mitiempo's Avatar
The best backing block for a seacock is epoxy or fibreglass epoxied to hull in my opinion. See Mainesail's how-to here :Replacing Thru-Hulls and Seacocks Photo Gallery by Maine Sailing at pbase.com
Brian
mitiempo is offline
post #12 of 12 Old 05-22-2009
Maine Sail's Avatar
Originally Posted by kingcan View Post
But as DrB suggests, we're feeling a little leery of the wood/water/seacock combo and planning the fix without wood (considering brass).
I would not advise brass. Solid fiberglass is much better as it will expand and contract at nearly the same rate as the hull, will be a permanent fix that will never need replacing, and won't suffer from galvanic corrosion issues.
If you don't want to make your own backing blocks McMaster Carr sells Garolite G-10 in 1/2" and 5/8" thicknesses which is a fiberglass/epoxy pre made panels. It's pricey but amazing stuff.
______
-Maine Sail / CS-36T
Maine Sail is offline
Leaking marelan seacock on brass thruhull sailbot Gear & Maintenance 34 12-11-2008 10:34 PM
The boat seems to be leaking water through the "tiller hole"... martsmth Gear & Maintenance 2 05-27-2008 12:16 AM
Assemble thru-hull & seacock...how? flyhop Gear & Maintenance 10 04-09-2008 05:53 PM
Leaking Seacocks and Sink Drains Tom Wood Buying a Boat Articles 0 09-11-2002 09:00 PM
Leaking Seacocks and Sink Drains Tom Wood Gear and Maintenance Articles 0 09-11-2002 09:00 PM
