spreader speakers - Page 2 - SailNet Community
post #11 of 13 Old 05-15-2009
timebandit's Avatar
Put them up there, they will make better targets.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #12 of 13 Old 05-16-2009
Here .. Pull this
I suppose I could throw them into the cockpit, but I was thinking I might get better coverage by putting them up on the spreaders.
The only downside I could see is that the speakers end up being 30-40' away from the cockpit and would likely need a bit stronger source to push them to get them with a reasonable volume.
Thoughts?
I echo what the others were mentioning about disturbing your neighbours and I guarantee that if you were berthed next to me I'd be up in the bos'n's chair snipping your wires before 24 hours had gone by.
Sailormann is offline
post #13 of 13 Old 05-16-2009
JimMcGee's Avatar
Originally Posted by mattdpeterson View Post
I'm looking to extend the audio system on my 32' islander from the cabin speakers out to something on deck.
I'm not sure if you have stern seats on your boat but the PO mounted a set of WM speakers under the stern seats on mine. Seems to work well and keeps the weather off the speakers at the dock. The stereo is wired so I can use the fade control to adjust the volume above and below separately. If you end up doing a stereo upgrade along with the speakers think about a wired remote at the wheel.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
"Marine" stereo needed? PrinceBuster Gear & Maintenance 135 11-30-2010 09:02 AM
Mast, spreader, shroud design, help Talisman66 Gear & Maintenance 1 11-23-2008 03:41 AM
Spreader for Islander 30 Bahama OopsIslander Islander 2 09-10-2008 11:52 PM
Cockpit Speakers? docinsand Gear & Maintenance 34 09-30-2007 05:14 PM
Spreader delmarva Gear & Maintenance 0 12-10-2004 10:01 AM
