Old 05-17-2009
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Fresh water foot pump (Whale) leaking
Hey everyone,
In the course of sailing our boat home, we discovered we had a leak in our fresh water system. When we found water coming into the bilge, imagine how happy we were to realize it was coming from inside the boat and not outside!
Anyway, it turns out the foot pump in the head was leaking. It's a Whale Gusher Mk II (I assume no longer available). The leak appears to be coming from where the foot lever enters the casing of the pump (on the bottom of the pump).
How do I determine if a new pump is required, or if the rebuild kit will do the trick? I didn't see any obvious cracks in the casing, but I haven't taken it apart yet. Thanks for your help!
-J
1984 Sabre 34 Mk I
Old 05-17-2009
Chances are likely, you have a torn diaphragm, since the foot lever is attached to one IIRC.
Old 05-18-2009
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
I had a similar problem last spring. I purchased the rebuild kit and installed it with great care. It did not solve the problem. I am now installing the new, replacement foot pump that I should have purchased originally. If your time is worth anything, buy the new pump.
Tundra Down
Old 05-18-2009
josrulz's Avatar
Unpaid Intern
You're probably right, sailingdog. I might just open up the thing and see if I can find an obvious cause first.
Tundra Down
Quick question--did you replace a MkII foot pump with a MkIII? If so, were the mounts in the same location or did you have to drill new holes, modify the mount, etc?
1984 Sabre 34 Mk I
Old 05-18-2009
Taking the pump out and opening it up will tell you where the problem lies... without doing that, anything else is guessing...and you'd have to do that to replace it or rebuild it... so that should be your first step.
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Beyond the Bucket Brigade Brian Hancock Seamanship Articles 0 01-01-2003 07:00 PM
Westerbeke 60 fresh water pump repair EdCraig Gear & Maintenance 4 06-29-2001 07:42 AM
