Can a Lewmar #43 replace a #40? - Page 2 - SailNet Community
post #11 of 15 Old 05-20-2009
Cal 9.2 SilverSwan
roline's Avatar
I saw a pair of 43ST on Ebay, older version with the black top disc. One of them had a broken ratchet gear and the seller claimed that the parts were available. I contacted Lewmar for a parts quote and I was informed that the 43ST parts were discontinued in 2003. They were manufactured in the early 80's. Lewmar tech support will have an exploded diagram, parts list and installation requirements.
I found a pair of Barient 27-48ST that turned out to be the closest physical match to the regular Barient 25's that I had. A drop in installation, same mounting pattern.
roline is offline
post #12 of 15 Old 05-20-2009
Originally Posted by Trekinout View Post
The #43 Lewmar is a standard winch (non self tailing), to the best of my knowledge, there is no #43ST (self tailer). I am replacing a Lewmar 40 with a #46ST, and the mounting holes are different. Anywhere I went with the biggest unit I could fit taking into account my grey hair factor.
Actually they DID make a 43ST. Past tense. Pair of them on my buddies boat.
Here is a the link to the schematic...
43 ST Oyster Bay Boat Shop
sailordave is offline
post #13 of 15 Old 05-21-2009 Thread Starter
jarcher's Avatar
Thanks, if the parts were discontinued in 2003, I probably don't want them! Thank for saving me some aggravation...
jarcher is offline
post #14 of 15 Old 05-21-2009 Thread Starter
jarcher's Avatar
The #40 and the #40ST have different mounting hole arrangements? Well, that's sure a clever idea
Were you easily able to just make new holes next to the old ones or did you have to close up the old holes for the new mount?
Thanks...
jarcher is offline
post #15 of 15 Old 05-24-2009
Not So Senior Member
Sapperwhite's Avatar
Like sailor dave said, they did make 43ST, but they are discontinued. I know as they are my primary winches (still solid since 1983!) You can't get many parts for them any more, notably drum bearings. If/when my drum bearings go I'm SOL. pawls and springs are still made though (same P/N across much of the product line).
Dictated, but not read.
Sapperwhite is offline
Corrosion on Lewmar winch drum & bearings Maxo Gear & Maintenance 5 04-05-2015 07:53 PM
Lewmar old-school winch maintenance geary126 Gear & Maintenance 17 09-21-2012 06:13 PM
Lewmar Traveller Shortman Gear & Maintenance 12 03-22-2009 08:35 AM
Lewmars Customar Service Stillraining Gear & Maintenance 3 09-28-2008 02:21 AM
Lewmar winch pawl problem ereuter Gear & Maintenance 4 08-04-2008 10:58 AM
