Old 05-18-2009
marcusn is on a distinguished road
Blisters on my hull! (see pic)
Yikes!
Getting my boat ready yesterday, I noticed a small area of blisters near the waterline. They don't appear too severe, but thought sharing with the experts here might yield another opinion.
My finger indicates scale. The general area affected is roughly a square foot.
Old 05-18-2009
Maine Sail's Avatar
Looks like shrink wrap gone bad.. Often times the shrink wrappers will let the gun sit in one place too long. The gel coat at the waterline has higher moisture content. The heat causes the moisture to expand rapidly and to fast to breathe out of the gel coat naturally.
This intense quick heat pops these little blisters off. If you never hit them with heat they likely never would have done anything or even been noticed. If you want to confirm this hit an area near this with an electric heat gun (do not get it to hot or you could burn the gelcoat). You will notice these things form and pop..
______
-Maine Sail / CS-36T
Old 05-18-2009
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
Originally Posted by marcusn View Post
Yikes!
Like the old saying goes........ Dammit.
John USYacht 27 "Cora Lee"
Old 05-19-2009
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Marcusn, these are very lite blisters (size of a coin) and looks superficial to the gelcoat, not affecting inner layers. Probably a bad gel application/treatment. A basic Google search will indicate how to fix this and in general state you shouldn't be concerned.
Nave Rara
Beneteau Oceanis 43
Old 05-19-2009
ASA and PSIA Instructor
MaineSail's explanation rings truer, especially of this is the only area. Blisters above the waterline are not common. I'd be concerned as when he repairs this area it is likely to end up a different shade than the rest of the topsides...looking like whaat it is...a patch. Ugh.
Old 05-19-2009
Here .. Pull this
Sailormann will become famous soon enough
It will be difficult to match the repair material with the original gel coat, but I think that if you were to add 2 or 3 vinyl stripes over it the diference in colour would be much less noticeable. If you use a colour that has a high degree of contrast it will almost disappear.
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 3 Weeks Ago 06:02 AM
Theory on cause of Fiberglass Hull Blisters travistowle Gear & Maintenance 121 10-31-2011 08:59 AM
Blisters Michael201 Gear & Maintenance 5 02-07-2009 05:36 PM
Hull Blisters Don Casey Gear and Maintenance Articles 0 09-11-2000 08:00 PM
