Fuel for an Origo Stove - Page 2 - SailNet Community
post #11 of 19 Old 05-20-2009
Coastal Traveler
nereussailor's Avatar
Send a message via Yahoo to nereussailor
I buy mine at Home Depot. Never used the boat stove alcohol never will. no soot
nereussailor is offline
post #12 of 19 Old 05-20-2009
jjablonowski's Avatar
I like 151 rum.
jjablonowski is offline
post #13 of 19 Old 05-21-2009
mitiempo's Avatar
And if you're cruising the Caribbean overproof rum is a damn site cheaper than stove alcohol if you can even find it!
mitiempo is offline
post #14 of 19 Old 05-21-2009
patrickrea's Avatar
Methyl Hydrate can also be used. Here in Canada, finding denatured alcohol is almost impossible but MH is available everywhere from Rona or Home Depot to Shoppers Drug Store. CDN$3 for a quart or so. The containers are even labelled as be used in "Marine non-pressurized boat stove".
Using marine and boat in the same sentence is a little redundant redundant but that's what it says.
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
patrickrea is offline
post #15 of 19 Old 05-21-2009
A word of caution about liquid fuel stoves. I have a methylated spirit stove on my boat. I filled it's tank up being very careful to not spill any(I used a funnel). I put the metho away, screwed the cap back on the tank, lit it up and nearly burnt the boat down. Thinking about my mistake it is now obvious that the vapour is heavier than air and must have gathered in and around the stove not unlike re-fuelling a petrol tank(you guys would call it a gas tank). I put the fire blanket on it but the convection current was strong enough to draw air in from underneath. In the end I had to give it a few bursts with a dry chemical extinguisher to put it out. I say a few as the heat from the ex-fire relit itself a couple of times. Quite a fright for me but very amusing for the people fishing on the jetty I was tied up to. I tell this story in the interest of preventing others from making the same mistake. I have sailed for decades but on dinghies and light weight day sailers. This was my first experience with a full size cruising boat. In the end I took the stove off the boat and experimented with it in the backyard. Far less frightening when you can run away! By the way dry powder is awful to clean up. Use a dust mask and vaccum up as much as you can, but you will be cleaning it up for a long time afterwards. I would be happy to answer any questions about this as I would like to prevent others from doing the same thing.
davewild is offline
post #16 of 19 Old 05-22-2009
Hinterhoeller HR28
pvanv1's Avatar
Yes, agree with all other posts. I have the same Origo 3000 2-burner unit, and love it.
Use Ethyl Alcohol (or methylated fuel substitute) only. Denaturing alcohol is the process of adding poisonous stuff in small amounts (acetone, whatever) so it's no longer "drinking" alcohol. Over-proofed rum would probably work fine, and likely smell nice as well.
The soot issue is hit or miss. I have had cheap hardware store alcohol that worked just fine, and likewise have had expensive "no soot" boat alcohol that stunk up the cabin, and caused soot on the pots. Just depends on what additive they used to denature the stuff.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
post #17 of 19 Old 05-22-2009
I get mine from Home Depot. Cheap and no problems so far.
sck5 is offline
post #18 of 19 Old 05-22-2009
Home Depot stove fuel
I have always used Home Depot denatured alcohol in my Origo 3000 stove as well, with no problems.
jgsteven is offline
post #19 of 19 Old 05-22-2009
Cabin boy
I have a backpacking alcohol stove that says "to eliminate soot, add up to 10% water".
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version. - Robert Gainer
JimHawkins is offline
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 41 09-24-2016 12:03 AM
Wallas Stove Woes (And Remedies?) badge Gear & Maintenance 11 05-06-2011 06:40 AM
Myth of Condensation in Fuel Tanks Martinini General Discussion (sailing related) 47 08-03-2009 02:22 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 08:00 PM
