What should I use to cleat my mainsheet? - Page 2 - SailNet Community
post #11 of 17 Old 05-22-2009
pdqaltair's Avatar
As stated, you won't get it out of the cleat in high winds.
Originally Posted by zz4gta View Post
Thumbs, I don't think that'll work in his case, as he wants to use the winch after he cleats it off. So the cleat would need to be on the highly loaded side. I've had trouble un-cleating a cam cleat before in high winds, and I'm not sure that would be the answer if there's little to no purchase on the mainsheet (assuming there's not since its lead to a winch).
Each sail in-use needs its own tackle or winch. Jammers are for lines that are adjusted less often (halyard) or to hold lines that are temporarily out of use (spin sheet when jib is up).
Stay safe. 3 winches are sort of the minimum. Jammers work on the load side, with cams on the tail side. Cams are for thing you can hand hold.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Writing full-time since 2014
pdqaltair is offline
post #12 of 17 Old 05-22-2009
Keeee...rist..
What's so damned difficult? Put a traditional horn cleat there, and tie off the main sheet to it when needed, with or without the winch.
Jeez....
Think this may have been "over-thunK"????
Bill
btrayfors is offline
post #13 of 17 Old 05-22-2009
GeorgeB's Avatar
My C34 is probably close enough to your 350 for me to weigh in on the subject. The mainsheet clam cleat is made of metal and is the largest of its kind made (I have the specs back home). Unfortunately, the 9/16 mainsheet is on the upper end of the line spec for the cleat, and if it is not properly set, it will release. The cleat is lower than the fairlead from the deck organizer to the winch so you have to remove the line from the winch to get a good bite with the cleat. I do this by pressing down on the sheet as Iím releasing it from the winch. I will often give it a tug after this to make sure the line is set in the cleat.
You do not have many alternatives. Catalina embeds a bronze plate in the coach roof and the cleat is drilled and tapped into it. There are no clutches made that fit the hole pattern (Iíve checked). Even so, a clutch is inadvisable. I know, Beneteau does it. But if you ever had a mainsheet hockle in a clutch, you will regret ever mounting the clutch (Iíve broached a Beneteau First 38 with just this same occurrence, not fun. And if you ever do it, donít have your wife on board!). Cam cleats are also not advisable as you need to pull on the line in order to release it. So again, with the forces on the mainsheet when you are most likely to blow the sheet, you again will be stuck. The best alternative is to get rid of the NER yacht braid mainsheet and replace it with something made of endura, dyneema, technora or the like. This will give you a smaller diameter line for the same strength and stretch properties and it will fit better in the existing cleat. The added bonus is it will also fit better on the ST30 winch.
GeorgeB is offline
post #14 of 17 Old 05-22-2009 Thread Starter
soulfinger's Avatar
Thanks for the advice all. George is rather right about most points. It is indeed an aluminum clam cleat (Ronson I think), and the mainsheet line does not like to stay put in it. The mainsheet itself certainly has enough purchase in it...the main reason we keep the sheet on the winch is because it stays put much better on the self-tailer than it does in the lousy clam cleat! To say that I ALWAYS need a dedicated winch for the mainsheet is certainly going overboard. I need to be able to occasionaly free the cabintop winches for traveler adjustments and furling the mainsail. I'm really leaning towards the camcleat, but I really don't want to have to drill and tap that mounting plate to install it. Grrr....
Trying a different size line for the mainsheet may be an option, though I think my winches are bigger than 30's. 32's I think.
soulfinger is offline
post #15 of 17 Old 05-22-2009 Thread Starter
soulfinger's Avatar
I want to add the appreciate btrayfors comment; I simple cleat would probably work fine.
post #16 of 17 Old 05-22-2009
Our 350 came with an aluminum racing clam cleat that works very well to temporarily cleat the main while using the winch for other things. You can see it behind the winch in this picture MobileMe Gallery. Not sure what brand it is, but I'll be on the boat tomorrow and let you know.
blakemiddleton is offline
post #17 of 17 Old 05-23-2009
pdqaltair's Avatar
Perhps you could take a second look at the traveller, because it should be ....
instantly adjustable too. I play the traveler more than the mainsheet to honest. It is much easier to grind in than the main when dumped in a gust, or should be. With the right purchase, you should not need a winch.
Unmanageable Mainsheet SEMIJim Gear & Maintenance 95 04-01-2011 10:36 PM
mainsheet sizing/load huguley3 Gear & Maintenance 29 04-30-2009 09:41 AM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 09:00 PM
Mainsheet Systems Dan Dickison Gear and Maintenance Articles 0 10-22-2001 09:00 PM
Schaefer Mid-ship Cleat Mark Matthews Gear and Maintenance Articles 0 10-01-2000 09:00 PM
