01-27-2011
Originally Posted by kcamfield
What did you end up doing? I am considering doing something similar at Beckett Point near Port Townsend.
Aside from what Minnewaska points, which is good advice... and I'd also recommend you read the POST in my signature.
You might want to check to see what the local regulations REQUIRE. Most areas will have at least some guidelines on what is required for a mooring. Most areas will also require a permit for placing a mooring, and often require annual or bi-annual inspections of the gear.
A good starting place to do research on this stuff is Hamilton Marine's catalog Mooring gear pages, as they have fairly solid basic guidelines for a reasonably sized mooring:
