-   -   Sealing the tabernacle to the deck. (http://www.sailnet.com/forums/gear-maintenance/54601-sealing-tabernacle-deck.html)
electricc0wb0y 05-23-2009 12:18 PM
The tabernacle bolts on my Spindrift 22 seems to have developed a leak. Four bolts run straight through the deck and into the cabin. Water appears to be seaping down one of the screws.
The tabernacle is simply a thick, bent metal sheet. There appears to be some caulking around the tabernacle, but I'm not sure if it is original.
What can I do to this to stop water from leaking through to the cabin? Should there be a seal or gasket between the tabernacle and the deck?
The deck does not appear to have significant damage.
saildork 05-23-2009 01:07 PM
Go to the 'Anything Sailing' forum and look for the sticky note by 'MainSail' entitled, "Sealing the Deck Core from Moisture." He gives a rundown of the procedure with a link to his more detailed article, for solving a problem such as yours.
WinterRiver 05-23-2009 02:02 PM
Here's the link: Sealing Deck Penetrations to Prevent Core Rot
Lot of other great how-to articles there too: Boat Projects
