05-24-2009
Which is torn...the sacrificial cover strip (mine is blue sunbrella, but on son's C22, it is white sailcloth) or the sail? The cover strip is intended to take the UV light abuse, while protecting the sail. During its life, the sail is exposed to sunlight only when you are actually sailing (a small percentage of the time), while the cover strip is always exposed. First, if the edges of the cover strip are only frayed, sailmaker may be able to still make repair. Cost for my repair was $180 vs. $1,500 plus for a new sail. If the cover strip is rotten (by tear test), the sailmaker can sew a new cover strip onto sail if the sail is still in relatively good shape. An experienced sailmaker, upon inspection of the damaged sail will be able to advise you whether your sail must be replaced or whether its just a simple repair that is needed. Since your sail seems to be old, if you put new cover strip, it might look better to put on a colored strip of sunbrella like your sail cover, since old sail and new strip will likely have significant different shades if you use white sailcloth. I don't think the sail tape is going to be satisfactory and if you continue to use the sail without proper repair, the damage is going to become worse.
