Filling 3/8" hole in hull. Boat in the water. - Page 2 - SailNet Community
post #11 of 24 Old 05-24-2009 Thread Starter
Nice idea
Originally Posted by celenoglu View Post
You might try to apply the underwater epoxy on the wood plug
Only problem is, the plug is where the engine mount has to go, and so the current plug has to be removed. I'm donning my wet suit in the next couple of days to see what it looks like on the outside.
Thanks for getting involved.
QueenElvis is offline
post #12 of 24 Old 05-24-2009
Here .. Pull this
Originally Posted by poopdeckpappy
Here's what ya do, first get your drill and a hammer, then find the hole you drilled, place your thumb over the hole, then smack it as hard as you can with the hammer, with your good hand throw the drill overboard as far as you can.
good luck, Hope that helps
It helped a lot. I looked around the site, and found there was a way to ignore you.
...just a thought - GO BUY YOURSELF A SENSE OF HUMOUR !!! Or perhaps consider something less exacting - knitting perhaps - 'cause I somehow feel that an individual with a propensity for drilling holes in the bottom of his boat and who is unable to laugh at themselves is likely to have a short, yet singularly undistinguished sailing career.
Sailormann is offline
post #13 of 24 Old 05-24-2009 Thread Starter
Originally Posted by Sailormann View Post
...just a thought - GO BUY YOURSELF A SENSE OF HUMOUR !!! ....
Oh dear, what have I started. I've been laughing at myself all day, and now you're taking me seriously. Perhaps you should buy yourself that sense of humour. Or knitting needles.
Thanks for your advice. I'll be waiting for more beans of wisdom, that's for sure.
post #14 of 24 Old 05-24-2009 Thread Starter
Thanks for your advice. I'll be waiting for more beans of wisdom from both of you, that's for sure.
post #15 of 24 Old 05-25-2009
billangiep's Avatar
Don't throw the drill away just yet... I'd move over to the opposite mount and drill another hole to let the water out.
On a more serious note using a piece of all-thread, fender washers and rubber washers you could fabricate a better fix till you get her hauled.
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
billangiep is offline
post #16 of 24 Old 05-25-2009
I have a stick of JB Weld, and I think it says it can cure underwater. You can patch it for now, but I highly recommend a proper fix when the boat is hauled. Also make sure your bilge pumps are working properly.
BlueWaterMD is offline
post #17 of 24 Old 05-25-2009
I would be worried about rotting out your engine stringer if you just plug the top of the hole. Getting something on the outside of the hull would be important to me....... if you are going to try waiting out the season, you might find a whole lot more work completely rebuilding your engine bed.
Good luck
boofus is offline
post #18 of 24 Old 05-25-2009 Thread Starter
Originally Posted by boofus View Post
I would be worried ...if you just plug the top of the hole. Getting something on the outside of the hull would be important to me.......
Thanks - but I'm ONLY interested in working on this from the outside of the hull. On the inside, I have a plug where the engine mount is going to be reinstalled.
I'm going to dive down tomorrow or Wednesday and attempt to insert a bolt with washers (if the curvature of the hull at this location permits), and bond it with some type of underwater-curing epoxy.
Unless better alternatives are presented here.... Thanks for your suggestions, everyone.
post #19 of 24 Old 05-25-2009
timebandit's Avatar
You might want to think about how hard that epoxied bolt will be to remove later and just use the butyl tape.
Originally Posted by pdqaltair
~ 5/16" with a washer gasketed with butyl tape. Push it in from outside and put a nut on it. If you use the nut to push the plug inside, you'll hardly leak a drop. This would probably be safe for a season. I have seen plugs like this serve in 500,000 chemical storage tanks for years... which is a little frightening (the gasket material varies with the chemical).
I like this idea a lot. I think this, combined with some underwater-curing marine epoxy, and I'll have a way to get through the season without hauling. And then after the fall haul, I'll go the Don Casey fiberglass repair way.
Of course, I've been wrong before. Like yesterday, when I didn't think about the drill actually going beyond the cradle to the hull, and beyond again....
Thanks, everyone. Well, almost everyone!
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #20 of 24 Old 05-25-2009
poopdeckpappy's Avatar
I've used this before JB WaterWeld on a old FG dinks bow eye at the waterline
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 03:54 PM
Project Boat? - Consider the Sad Case of K28 NCC320 Boat Review and Purchase Forum 3 01-07-2009 09:31 PM
Life in the fast lane, well for one day at least... Lancer28 Learning to Sail 8 11-27-2007 10:36 PM
Fill that hole GoodOldBoat Good Old Boat 0 07-23-2007 09:54 AM
