Old 05-25-2009
vtsailor11 is on a distinguished road
Yanmar Intake Silencer
I have a Yanmar 3YM20. The engine was just reinstalled following a piston repair. Now the engine stinks up the cabin when running. While trying to track down the source of the smell, I noticed that the air intake silencer was expelling air as if it were an exhaust. Is it supposed to do this?
  #2
Old 05-25-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
It sounds like you have a intake valve hanging up (Not closing)! Then on the compression stroke the piston just pushes the air/fuel mixure past the open intake valve and out the breather!
Never Forgotten
  #3
Old 05-25-2009
JohnRPollard's Avatar
Moderator
Definitely not. That's potentially dangerous, too. Diesel exhaust only has a small fraction the CO content of gasoline exhaust, but if it's discharging into your cabin for long durations it could eventually build up to poisonous levels.
Who did the piston repair work?
  #4
Old 05-26-2009
timebandit's Avatar
timebandit is on a distinguished road
Intake valves adjusted to tight
Rings on new piston not seated yet
Crankcase vent hose not attached properly
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
  #5
Old 05-26-2009
Another mechainc looked at it today. Turns out what felt like air coming out of the silencer was actually air going in (confirmed by smoke test). The smell is reported to be "new engine" smell.
You may post attachments
You may edit your posts
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 08:23 PM
Beneteau vs. Yanmar – Green vs. Red Cooling Fluid Swesail Gear & Maintenance 37 04-14-2009 12:32 PM
Yanmar 2QM15 raw water pump problem menado Gear & Maintenance 3 07-23-2008 02:20 PM
Yanmar 3GM30 salt water in intake manifold Peregrina Gear & Maintenance 18 04-06-2008 07:10 PM
Yanmar 3GM30 Salt water in intake manifold Peregrina SailNet Website Technical Support 0 03-31-2008 02:51 PM
SEO by vBSEO 3.6.1
