05-27-2009
Tefgel isn't used to "bed" hardware, but to coat fasteners, so that the fasteners and the mast are less likely to have galvanic corrosion occur between them. You can use Lanocote to much the same end as well.
I would recommend that you seal where the wires enter the mast, but leave the mast bottom unsealed. The rubber grommets aren't for sealing, but for chafe protection.
