Starter battery quits at crank - Page 2 - SailNet Community
post #11 of 13 Old 05-27-2009
timebandit's Avatar
Lazy man's test---
Volt meter on battery POSTS (not the terminals that may be attached)
12+ volts
Turn starter
Batery goes to 0 volts---change out battery
True battery voltage stays at 12+ volts but instrament panel goes dead---
Clean posts and try again--
Still no power to the starter but battery voltage is still good---
Clean other end of both battery cables--
Still no power to starter---
Change out battery switch
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
timebandit is offline
post #12 of 13 Old 05-27-2009 Thread Starter
JeffBurright's Avatar
You cracked the case!
Thanks everyone for the advice. It turns out the cable from the battery into the selector switch had shrugged its bolt and nearly shaken off its post. I tightened it back down and she started right up. Like most problems on this boat, I just had to pick a line (wire, hose, rope) and follow it far enough through the places boat builders usually try to keep hidden.
JeffBurright is offline
post #13 of 13 Old 05-27-2009
timebandit's Avatar
Kewl!
Rick
Mac 25
Copernicus
Southern California
Yanmar Starter dave6330 Gear & Maintenance 21 12-18-2015 06:52 PM
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 10:17 AM
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 08:07 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 09:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 08:00 PM
