Yanmar 2QM15 - Changing the Fuel Filter - Page 2 - SailNet Community
post #11 of 16 Old 05-28-2009
Steve - I am not doubting you. But what exactly is an air slug? And how would filling a filter =, say 3/4 full, leaving 1/4 volume to be forced/ bled out by incoming fuel be more of a problem that having it empty, and having to force out / bleed the whole volume.
Again. not being a smart$ass!! Just would like to learn - see if I am overlooking something. I haven't had a problem with filling them as much as possible b4 bleeding, but have only had to do it a couple of times.
Northeaster is offline
post #12 of 16 Old 05-30-2009
An Aussie Sailor
Mipcar's Avatar
Having suffered from a stoppage due to a fuel blockage,I reckon you cannot have too many filters.
My set up is a follows.
Tank to line with fuel bulb for priming to first canister filter "Ryco" brand, larger and cheaper to replace element the the genuine Yanmar article, connector line to Yanmar canister filter, line to engine mechanical pump then the small secondary filter.
The head of fuel in the tank pretty much will refill both the large canister filters but the primer bulb speeds it up.
The manual lever on the engine driven pump then primes up the low pressure side of the system. No problems re-starting, no airlocks on high pressure side.
I also regularly add a water absorbent additive to the fuel and a biocide.
Mychael
Mipcar is offline
post #13 of 16 Old 05-30-2009
Splashed
JomsViking's Avatar
1. Put a plastic bag around the filter before removing it using the right tool. That will capture all the diesel. Put the plastic bag under the "belt" of the filter tool, the grip will not be as firm, but should be adequate still.
2. Bleed the system, it takes 2 minutes.
If it is still running a little rough, loosen the bleed-screw first, and if that's not enough, loosen the nuts on the injectors one by one, while the engine is running bleeding that last air out that might have been captured. But be careful though, it can easily penetrate your skin.
Typically it's a 10 minutes job.
Originally Posted by backcreeksailor View Post
This looks simple enough, unscrew the bell, change out the filter, screw it back on. But I've already had a couple 5 minute jobs turn into 5 hour jobs, (e.g. the frozen zinc I'm still trying to remove...). So...
When I unscrew the bell that houses the filter, how much diesel fuel is likely to spill out? And what's the best way to contain it? (I don't want to reintroduce the diesel smell that took me a month to get rid of after the first got the boat).
Am I going to have to bleed the system after I do this, or will just cranking it work out any air in the system?
JomsViking is offline
post #14 of 16 Old 05-30-2009
If you pre-fill the filters you can create an air slug by trapping some air at the top of the filter, then pumping the lift pump a bit which forces the air into the supply lines. You think you have clear fuel to the secondary so you stop priming and button every thing up. But in reality their is air in the lines behind the clear fuel. You start the motor, which runs fine for a few minutes until the air slug is forced into the high pressure side. Then the engine quits and now you have to bleed the low pressure side, then the high pressure side too. A mechanic explained this to me. I realized I had done this exact thing myself. You can get away with a little pre-filling at little fuel but I'm not really sure it's worth it.
SteveInMD is offline
post #15 of 16 Old 06-01-2009
Disposable diapers soak up more liquid than anything else on earth. Put one beneath where it will catch any drips and you will be in good shape
sck5 is offline
post #16 of 16 Old 06-04-2009
we went a added a small electric fuel pump between the Racor and the engine. Put a switch close by. Works super easy to prime when changing the racor or the engine filters. I just flip the switch and open the bleeder. Pump was around $20. Have the Yanmar 2GM
Thisisus
Islander 32
Mobile AL
thisisus is offline
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 41 09-24-2016 12:03 AM
Fuel filter replacement on Yanmar 3GM30F gsyversen Gear & Maintenance 7 06-13-2008 03:18 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 08:00 PM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 08:21 PM
