Old 05-27-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Using Wiring Harnesses
The "Crimp vs. Solder" thread made me curious about something ...
Here on land I sometimes make wiring harnesses to get signals and power from one place to another in an organized way and to minimize the connection points and use of terminal blocks. Question is, is it good practice to do this on a boat ?
If wiring harnesses are used on a boat, are there special kinds of connectors that are used, special ways of sealing the harness connectors, etc, to protect them from corrosion ? Where are wiring harnesses typically used on a boat ?
What are you pretending not to know ?
Old 05-27-2009
mazzy's Avatar
mazzy is on a distinguished road
Did you see this product?
EzAcDc - Simple Systems for Boat Wiring and Marine Electrical
What I don't like in this harness is the use of 16ga wire. It's overkill on a 25 footer, but I'm rewiring with 14ga. Also, looking at the measuring diagram from the website, it points out how simple a sailboat's wiring really is. There's no circuits in this harness for water pumps, inverters and the like.
Another thing to consider; even with a harness you have to mount wire clips, run split conduit or otherwise do all the tidying work which is probably more than 1/2 the job!
FWIW
Mike
Old 05-27-2009
badsanta is on a distinguished road
I replaced my wiring harness on my yanmar engine. I am sure it will last as long as the first one, but was very disappointed with the quality. No tinned wire, thin untined ground connectors. But the other option of making my own harness was to much. If I ever re power I may. But for the cost it should have been top notch.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Learning to Sail Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Seamanship Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Gear and Maintenance Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Cruising Articles 0 05-06-1999 08:00 PM
