The SPOT Messenger - Page 2 - SailNet Community
post #11 of 27 Old 05-27-2009
It can't be one way communication only because SPOT does give you a signal that the message has been received. I believe both lights stay on for a few seconds. I wish they stayed on longer because it's easy to miss the signal.
Again, I think it's a very useful tool.
SteveInMD is offline
post #12 of 27 Old 05-27-2009 Thread Starter
Originally Posted by brak View Post
I think this is not entirely true.
1) 121.5Mhz EPIRBs have been completely phased out afaik, and current EPIRBS produce no local signal of any kind. The SAR relies on the 406Mhz signal and, preferably, the GPS location sent with it.
Brak—
The 406 MHz EPIRBs still broadcast a 121.5 SART signal. From the ACR website on a GlobalFix 406 MHz EPIRB
Transmits on 406 MHz (COSPAS-SARSAT) with your registered, unique, digitally-coded distress signal, and 121.5 MHz (SAR homing frequency)
2) EPIRB signal registration with Coast Guard is not instantaneous. In fact, according to people that run Boston center that listens to EPIRB signals, it may take up to 12(!!) hours for them to get the signal. Don't ask me why, but thats what they say. Perhaps there is some handoff between the satellite network and their equipment.
That isn't much different from what happens at the SPOT messenger center when you push the 911 button.
3) EPIRB coverage has its own gaps. On the other hand, Globalstar simplex network that is used by SPOT is in good shape and has no known issues.
The COSPAS/SARSAT network is a lot more reliable and has broader coverage than the Globalstar network, which has well-known satellite reliability problems.
4) There is no way to know whether your EPIRB works until you actually use it, when it may be too late. As an engineer, I can't rely on any "self test". The only test of the device is actual activation and receipt of signal, end to end. SPOT is tested virtually all the time.
True, but modern manufacturing systems and field use of the EPIRBs means that they're pretty reliable.
5) SPOT in tracking mode provides past history of your movement, as opposed to EPIRB which is essentially a single point. This may be very important in SAR because if they know where you've been they may have easier time finding where you are going.
So, personally, I think SPOT has a number of advantages over EPIRB. That said, I would prefer to have both for any offshore sailing - you never know what gives Locally SPOT is my choice.
Very true, but the SPOT Messenger doesn't have the proven field track record that the 406 MHz EPIRBs have yet.
sailingdog is offline
post #13 of 27 Old 05-27-2009 Thread Starter
No, it does not acknowledge the message receipt AFAIK.
post #14 of 27 Old 05-27-2009
old guy :)
rikhall's Avatar
We have a SPOT - we love it! We are taking our new to us Irwin Citation 34 home to Canada from Annapolis MD. We push it around noon and when we reach our destination. Or other times if we are near something cool - like the Statue of Liberty or half way through the C&D canal.
If you want to see what it looks like - look at our sailing blog at:
trip blog at: Mystery - the Trip Home
Rik and Linda
Mystery
Irwin Citation 34
Irwin Citation 34
Mystery
rikhall is offline
post #15 of 27 Old 05-27-2009
Sea Slacker
That signal is just a notification that SPOT is "no longer sending". It does not mean SPOT knows that message was received. In fact, SPOT will tell you that "message was sent" even if it actually was not. Simplex is "one way".
brak is offline
post #16 of 27 Old 05-27-2009
I use my spot for backpacking all the time. I think the confusion may be that the SPOT does not let you know if a tracking messages has been successfully sent. However, it does let you know if an OK, HELP, etc... message has been sent. The corresponding light will continue to flash until the message has been sent. If I recall correctly 2 solid lights will indicate a transmission, and 2 alternating lights indicate a failure. However, even after a failure a the light will continue to flash until the message has been sent. No flashing means the message was successfully sent (unless you have turned on tracking mode in which case the light will always be flashing).
2005 Catalina 250 WK #847
AaronOnTheHudson is offline
post #17 of 27 Old 05-27-2009
Sea Slacker
SPOT does not know if a message was sent. There is *no* downlink from the satellite back to SPOT. It is a one-way communication, no matter what lights show.
Globalstar - Wikipedia, the free encyclopedia - read about "simplex".
Simplex communication - Wikipedia, the free encyclopedia
brak is offline
post #18 of 27 Old 05-27-2009
S/V Lilo, Islander 32
I think the confusion may be int he terminology, SPOT can tell you it sent the message, but doe snot know if it was received by the satellites or any other systems on the other end. Of course I do not own one, so I am not sure, but I think that's what the diffrent people might be saying?
I am a gadget geek and think the spot is very cool and useful, however I fear that on a long trip, if we set up to send messages every so often so people know we are OK, I know I will drop it in the bilge, let all the batteries die, or some how break the system and freak the family out when we do not check in for a few days.
I am still pondering if it is better to tell them "We will be fine, don't worry" and not check in regularly, or check in, but risk a major panic attack due to an accident?
I am thinking to get one, but only send an OK message if we are long over due but still OK. Kinda halfway in between. Being over due is likely, breaking the thing is likely, but having both go wrong and start a panic is a bit less likely.
Any other thoughts on the psychological side of spots on long distance cruising?
Thanks
Bryan
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #19 of 27 Old 05-27-2009
Sea Slacker
I had spot operate for 3 days in a row. I also used the same set of batteries to operate it intermittently (4-5 hours a day) for an entire sailing season, many weekends. According to manual with appropriate batteries it will work in tracking mode for 14 days, and I think that's about right.
On my boat I have a place under the hardtop where it sits clipped on a piece of webbing, so it's easily accessible but can't go AWOL and is out of the way.
I realize it's limitations but I think it's features are certainly worth more and overall no other device gives that much good functionality for such (relatively) small price.
brak is offline
post #20 of 27 Old 05-27-2009
Dawg,
Nice write up, but there is one thing wrong with #1 in your case.
1. I'm OK
2. Help
3. 911—send help
4. Tracking update
I think it's a false statement.
denby is offline
Looking for sailors with Spot Messenger Shared Pages. SVlagniappe Cruising & Liveaboard Forum 3 05-08-2009 02:49 PM
SPOT MESSENGER - Tracking Wild Goose Pamlicotraveler Cruising & Liveaboard Forum 37 07-19-2008 03:16 PM
Spot Sattelite Messenger RXBOT Gear & Maintenance 9 06-14-2008 08:14 PM
Spot sailortjk1 Gear & Maintenance 9 03-27-2008 07:43 PM
Spot Personal Messenger and GPS teshannon Gear & Maintenance 5 01-23-2008 03:23 PM
