View Poll Results: What method do you use to mark depth on your anchor rode?
Zip Ties - 1 for 25', 2 for 50' etc... 14 17.28%
Color Coded Paint 10 12.35%
Color Coded nylon fabric threaded through the strands 26 32.10%
Other Method 25 30.86%
I just guess based on how much rode is left in the locker... 6 7.41%
Voters: 81. You may not vote on this poll
Like Tree1Likes
Old 05-31-2009
backcreeksailor's Avatar
1979 C&C 30 Mk I - 2QM15
backcreeksailor is on a distinguished road
Marking your Anchor Rode for Depth?
How many of you mark your anchor rode for depth? And what methods do you think work best both in daylight and after dark conditions?
Old 05-31-2009
scottyt is on a distinguished road
both of mine are marked, the one that came with the boat has plastic tails every ten feet and they are numbered. the new one i bought has small line tied in to it at 25, 50 and 75 feet. i dont need the new one with numbers, its kind of obvious which one i am at. the first is hard to see at night unless i have my headlamp on.
Old 05-31-2009
Cloth markers in the rope portion and cable ties in the chain portion.
Old 05-31-2009
I've seen elsewhere on the net where people say that they mark their anchor chain. But unless you have an "all-chain" anchor line, why would you ever need to bother with marking the chain?
(In my case, I have a 30' boat and I bought a 30' chain to attach the rode to. So anytime I put the anchor out, the entire chain is always going to the bottom anyway).
Old 05-31-2009
JomsViking's Avatar
Splashed
JomsViking is on a distinguished road
Pieces of cloth in the chain - 1 for 10 meters. 2 for 20, 3 for thirty....
Starting over at 50 meters if I really had that much chain
Chain only for the main anchor. Not because I need it for chafe protection but because of the shorter scope required.
Watch great footage about the story of one man’s slow odyssey around the UK:
Old 05-31-2009
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
These work well for me, but then I only have 50' of chain
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 05-31-2009
Craig Smith's Avatar
Anchorsmith
Craig Smith is on a distinguished road
Arrow
Lots of cruising folk have longer lengths of chain than is always deployed, so marking the chain as well as the rope is necessary.
We use reinforced awning fabric, on both the chain and the rope. This is soft, easy on the gypsy, durable, and very easy to add and maintain.
Brighter colors are best, and a flashlight on the foredeck is necessary for nighttime use!
More, including photos, here:
www.rocna.com/kb/Counting_chain
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Old 05-31-2009
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Originally Posted by T37Chef View Post
I have the same setup
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 05-31-2009
I have 60' of chain or so....but can anchor in as little ad 3' of water with no trouble...since my board up draft is 16"... so, marking the chain makes sense...
Old 05-31-2009
Sequitur's Avatar
... a logical conclusion
Sequitur is on a distinguished road
My main anchor is on 100 metres of chain, which I count from the cockpit with an AutoAnchor, a wonderful little New Zealand device.
As a back-up, I have the chain tagged with bright nylon strips: one at 20, two at 40, three at 60 and four at 80 metres. My three other rodes are also similarly marked.
Cheers,
Michael
2007 Hunter 49
marking a mooring ball... kokopelli9 Gear & Maintenance 9 02-29-2008 03:03 PM
Tender marking requirements joub General Discussion (sailing related) 1 02-20-2004 08:15 AM
Marking Chain pblais Gear & Maintenance 10 05-12-2003 08:09 AM
