Blogs
User Name
Old 11-13-2002
welch welch is offline
welch is on a distinguished road
Jib back-up
Thinking about systems backing-up systems, is it possible to have a split drum jib roller furing that can be removed in the event of breaking/malfunction, then go back to a hanked-on jib sail?
Lots to learn. Dave.
Old 11-13-2002
Sailmc Sailmc is offline
Sailmc is on a distinguished road
Jib back-up
If your furler breaks you can always raise and lower the sail in the luff groove. If you want heavy weather backup you could get a small storm jib with luff tape to fit on your extrusion. An inner forestay that take a hank on jib is a sure fire solution but is expensive to retrofit properly and is a real pain to deal with 99% of the time when you don''t need it. If you sail coastwise I wouldn''t bother with that option.
Old 11-13-2002
paulk paulk is offline
paulk is on a distinguished road
Jib back-up
The trick is to figure out about three hours before you need to that you have to take down the roller-furler jib and put up the other one. After the wind has piped up is not the time to have to do this. If you can arrange to be 99% right with your timing, NOAA could use you.
Old 11-14-2002
Jib back-up
I guess my question was misunderstood. I was thinking more in the lines of; IF I am at sea and my roller furling breaks, IS it possible to have a back-up jib using a regular hanked on sail? Time probably won''t matter. Just looking for system back-up information. Thanks ! Dave
Old 11-14-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
Jib back-up
Sure but not with hanks. One set up that I have seen uses webbing loops that go around the headfoil. These can actually be used when the sail is fed into the luff bolt rope track as a way to keep the sail in control if you are doing a sail swap. Even if the furler fails there are things that you can do. I have removed the sheets and sailed in circles to unwrap or wrap a sail on a jambed furler. Once unfurled you can drop the sail to the deck and just use the luff track to raise and lower sails. It is unlikely that the halyard would jamb once the sail is unrolled.
Display Modes
vB code is On
Spartalk is back AJS General Discussion (sailing related) 0 07-21-2004 08:02 AM
Aquarius 23 wheel steer back to tiller woodyr Gear & Maintenance 0 06-24-2004 08:13 PM
Cruisers Forum is back! GordMay General Discussion (sailing related) 0 04-27-2004 01:33 AM
Offering smiles and a strong back... bubbage Crew Wanted 0 10-13-2003 01:13 PM
Clearing Customs St Vincent/Grenada and back hervel General Discussion (sailing related) 3 05-20-2001 06:04 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
