Twin sheet lead blocks need rubber stand up? - Page 2 - SailNet Community
post #11 of 16 Old 06-03-2009 Thread Starter
Break, curse, fix, repeat
bwindrope's Avatar
I'm going down to Aeolus today and will take a close look at whether I think a tennis ball approach or one of the other good ideas will work best. Thanks for the link to that performance sailing site, it was new to me. None of that stuff would fit my blocks however.
I just received some new track car single blocks from Garhauer that I'm going to use to create a fair lead to my winches. I have to do some surgery to add these new cars as the end track bolts of course are meant to keep stuff from sliding off. Getting to the head of these bolts on a Gulf 32 requires the removal of some paneling and stuff, but not too bad. These new blocks look great!
I'll try to remember to post a picture of whatever solution I end up with, and thanks as always for the help.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #12 of 16 Old 06-07-2009
NON member
AE28's Avatar
Originally Posted by bwindrope View Post
That's a clever idea that I can see working well. I wonder how the inner tube stands up to UV? How long have you had this in place and under what sort of conditions? A picture would be great.
b'wind
Sorry it took so long to post the pix - had to take it first.
This is season #5 for the inner tube.
Pretty, it ain't, but it sure works!
Paul
AE28 is offline
post #13 of 16 Old 06-07-2009 Thread Starter
bwindrope's Avatar
AE28,
That's awesome. Great shot, great idea. I went and checked my block and think I could possibly get the tennis ball or tube to work. Of course the twin sheet block is a different arrangement than your stand up block, but it would probably work.
Today I think I'll start to remove my T-track so I can slide on my new fairlead car blocks, and will bring a tennis ball and some old tube to try out both.
I took a bunch of my wife's family out sailing this week and most of them had only had traumatic experiences sailing with bad sailors in SF Bay in typically harsh conditions. Had 15 knots and a perfect sail, other than this damn twin sheet block continuing to lay down and force my genoa sheet to ride over the sharp edge of the stainless steel frame. They didn't know it was possible to sail fast and happily without fear and screaming. It's so nice to give people positive experiences on boats.
Aeolus
Gulf 32
post #14 of 16 Old 06-07-2009 Thread Starter
bwindrope's Avatar
Photo of genoa block
Here is a photo of my T-track with the genoa twin sheet block I've been discussing. I installed my single stand up fairlead block aft of it today, so I can get a fairlead to my winch regardless of the position of my main sheet block. You can see here how the genoa block lays over on its side and the sheet rides on the frame. It doesn't look too bad here, but when the sail is raised, the angle to the block is more acute and the problem even greater.
Aeolus
Gulf 32
post #15 of 16 Old 06-08-2009
NON member
AE28's Avatar
b'wind
Couple of (probably) stupid suggestions you've undoubtedly already tried:
reverse the fore and aft positions of the two leads and/or turn the grey lead 180 degrees so it tilts inboard rather than outboard.
Paul
AE28 is offline
post #16 of 16 Old 06-21-2009 Thread Starter
bwindrope's Avatar
Problem solved
Thanks to everyone for advice and encouragement. I've gone with the inner tube solution for now and it is working well. In this picture the inner tube is a little higher on the block than it is now. I moved it down a little to not rub the sheet.
Between the new Garhauer stand up block fairlead, and this ability to keep the twin sheet genoa block from flopping over on its side, I feel like I have seriously upgraded the functionality and durability of my headsail system.
Sailed today in decent wind and everything worked great. For the first time ever, I could move my forward block forward for broad reaching and then back for close reaching without rerouting the sheet to the winch, or constantly adjusting the block to keep the sheet on the roller and not the housing. Hooray!
Aeolus
Gulf 32
Reading Flow and Making Adjustments Tom Wood Learning to Sail Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Seamanship Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Gear and Maintenance Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Cruising Articles 0 09-23-1999 08:00 PM
