Butyl Tape - Did I find the right stuff? - Page 4 - SailNet Community
post #31 of 34 Old 03-10-2010
Copa—
I've never found the stuff at a marine store. Try glass repair shops, try RV dealerships, try small local hardware stores... that's where I've found the stuff pretty much.
sailingdog is offline
post #32 of 34 Old 03-10-2010
Butyl Tape Source
I recently posted the same question on the Google Pearson-Boats group list.
Someone responded with the following info:
PPL Motor Homes REFERENCE: MAGNOB161
10777 Southwest Freeway
Houston, TX 77074 DATE ENTERED: 10/07/08
713-988-5555 EMPLOYEE: Cart - Rick Hadley
800-755-4775
PART UNIT TOTAL
QUANT. NUMBER DESCRIPTION PRICE COST
2 38-1622 BUTYL TAPE 3/16 X 1 5.99 11.98
Hope that helps.
Mike
OasisII is offline
post #33 of 34 Old 03-10-2010
'87 Pearson 27'
jackytdunaway's Avatar
Check this stuff out. i got someone to send me a sample 12' long last year of 4" wide. Best stuff and just the right size. if we could get someone like Sailnet or Defender to order it and sell in small quantities it would be great
Permatite® 250-H Butyl Tape
High Cross Linked And Modified Butyl Rubber Compound
Developed for maximum adhesion to most all surfaces, Permatite 250-H Tapes exhibit excellent performance in areas where joint movement, expansion and contraction are present. When specialty sizes are required, Permatite can provide unlimited profiles in extruded tapes. Permatite's extruded tapes are designed to form an air and water tight seal while conforming to irregular surfaces. Ease in application make 250-H extrusions result in instant cost and labor savings.
Tapes : Permatite® A Division of DSI
jackytdunaway is offline
post #34 of 34 Old 03-10-2010 Thread Starter
Unpaid Intern
josrulz's Avatar
Originally Posted by jackytdunaway View Post
Check this stuff out. i got someone to send me a sample 12' long last year of 4" wide. Best stuff and just the right size. if we could get someone like Sailnet or Defender to order it and sell in small quantities it would be great...
That's more like what I'm referring to. Looks very thin too. Oh well, the stuff I have will work just fine. It's just more time-consuming to use.
1984 Sabre 34 Mk I
josrulz is offline
Butyl tape underwater brak Gear & Maintenance 16 04-06-2009 05:29 PM
Rebedding toerail...butyl tape mess Finallybuyingaboat Gear & Maintenance 8 03-30-2009 01:36 PM
Bilge mold and where do I get that black sealing stuff... Hargadoo Gear & Maintenance 5 11-24-2006 09:02 PM
Transiting the ICW, Part One Sue & Larry Cruising Articles 0 01-03-2002 07:00 PM
