Old 06-05-2009
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
Butyl Tape - Did I find the right stuff?
This might ultimately be a question for Maine Sail, but I'm sure others know as well. I've read a good bit about butyl tape on Sailnet, and have discovered that at least some of my boat's hardware was bedded with it, and definitely the hull-to-deck joint.
I've also read here that some things are called "butyl tape" but aren't really.
So I went to my local RV shop and found this stuff, which is off-white/beige, and I'm very happy about that. Should blend nicely. It's labeled as "Butyl Tape", and feels like the putty that shows up oozing from stuff on my boat.
Is this the right stuff?
By the way, if it IS the right stuff, should I use butyl tape to rebed my in-board, deck-mounted, genoa sheet tracks? They are through-bolted and need to be rebedded.
Thanks!
-J
1984 Sabre 34 Mk I
Old 06-05-2009
Irrationally Exuberant
arf145 is on a distinguished road
Pretty much looks like the stuff Jos, though yours appears thicker and lighter colored than what I have. Mine came in a paper-backed roll like that. The stuff should be quite sticky.
BTW, it's what I'll be using to rebed my genoa sheet tracks sometime this year.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 06-05-2009
dgr dgr is offline
dgr is on a distinguished road
That's the stuff
Just a Columbia 28
Old 06-05-2009
you're good to go... it's really easy stuff to clean up too...
Old 06-05-2009
josrulz's Avatar
Unpaid Intern
Sweet. I wanted some stuff that was thinner, so I'll probably have a lot of "ooz" with this stuff when I tighten down hardware, but I think it'll work just fine. I'll use lots of painters tape.
As for genoa tracks, would you use this on the bolts too? I was figuring I'd wrap some around the bolts near the head before tightening everything down. Is this what I should use, or should I use a different sealant at the tops of the bolts?
Thanks!
-J
1984 Sabre 34 Mk I
Old 06-05-2009
pdqaltair's Avatar
pdqaltair is on a distinguished road
No tape. Trim with a knife a few minutes after tightening.
Thanks!
-J
Only light pressure is needed. The tape will just give it something to stick too, in my opinion.
Yeah, same stuff under the bolts.
My favorite uses are stanchion bases and running lights. Consider something else (3M 4200?) where adhesive is needed.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 06-05-2009
josrulz's Avatar
Unpaid Intern
Thanks pdqaltair. I've been using 3M 101 so far in places where I need adhesive, like the chainplate covers, which aren't through-bolted on my boat, so butyl wasn't recommended. Of course, I'm talking all deck stuff--I haven't done any real work below the waterline yet.
1984 Sabre 34 Mk I
Old 06-05-2009
jackytdunaway's Avatar
'87 Pearson 27'
jackytdunaway is on a distinguished road
I found 4" wide x 1/16" thick gray from a company called permatite. Since they only sell it in case of 200' rolls i had to find a distributor who was nice enough to have Permatite run me a sample about 12' long. it is great stuff
Old 06-05-2009
Maine Sail's Avatar
I thing Grainger sells a very similar product that us wide and thin.
The op's stuff looks like butyl but it is quite thick..
______
-Maine Sail / CS-36T
Old 06-05-2009
fendertweed is on a distinguished road
I'll have to look for some, good idea for running lights.
slight thread drift ... I used 3M 4000 to bed my stanchions ... less permanent than 4200 or 5200 and with more UV protection ... I let it set up for a day snugged just slightly, to form a gasket, then tightened it up 24-48 hrs. later.
Jon
S/V Catalyst:
Pearson 26 #1200
Butyl tape underwater brak Gear & Maintenance 16 04-06-2009 05:29 PM
Rebedding toerail...butyl tape mess Finallybuyingaboat Gear & Maintenance 8 03-30-2009 01:36 PM
Bilge mold and where do I get that black sealing stuff... Hargadoo Gear & Maintenance 5 11-24-2006 09:02 PM
Transiting the ICW, Part One Sue & Larry Cruising Articles 0 01-03-2002 07:00 PM
