Old 06-05-2009
Cal20
KB7EWA is on a distinguished road
Filler material around keel
What is the proper material for smoothing the transition around an iron keel to a fiberglass hull. This is a Cal 20 in freshwater. I would like to pull the keel bolts to check them but in order to do so I'll have to remove the filler material. It is also coming off in a few places so I was just thinking I'd replace it. I am assuming that Bondo is a no no?
Jim
Old 06-06-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
I think any hard brittle material will just crack and flake off. I've used 5200 to fill in the joint between my iron keel and the hull and it seems to work fine.
Old 06-06-2009
BarryL's Avatar
BarryL is on a distinguished road
Quikfair from system 3
Hello,
When I had to fair my keel I used Quicfair from System 3. It's an epoxy based fairing compound that is light weight, easy to apply, and easy to sand.
I bought it from Defender, which is one of my favorite places to buy marine stuff.
http://www.defender.com/product.jsp?path=-1|10918|12626|714831&id=1196400
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 06-06-2009
GilStump's Avatar
Member at large
GilStump is on a distinguished road
I am having the same problem. A friend recommended Gflex fro West System. Talked to a guy there, and I'll be going with that.
Cheers!
Gilligan Stump
s/v lunasea
Please don't google me.
Dropping the Keel matt2 Gear & Maintenance 13 02-06-2009 10:11 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
