Is it normal for the bowl to not fill? - Page 2 - SailNet Community
post #11 of 20 Old 06-08-2009
In many marine toilets the toilet needs to be mounted at a height so that the water level outside the boat is about 1/4 way up the bowl to get the bowl to fill to the same level. Put a temporary clear hose on the flush water through-hull and mark the water level on the wall beside the toilet with a piece of tape or a pencil, then install the toilet at a height that will put the line 1/4 way up the bowl. If the toilet is higher than the water level it will pump OK but it won't partially fill. The water line between the hand pump and the back of the toilet where the water goes into the bowl needs to be run several feet above the water line and have an anti-siphon valve at the top of the loop to make sure the toilet won't start a siphon and sink the boat.
rob8888 is offline
post #12 of 20 Old 06-08-2009
It's time for all you geniuses to think out of the box. It's time to figure out a better way of dealing with waste on a sailboat easily and responsibly. I am so disheartened to read these threads. So many things go wrong, so much time wasted working on a fix. There's got to be a simpler way to move waste from you to the holding tank.
I started sailing when I was 12 and at 30 bought a cruising boat - 33 Hunter. Used, clean, surveyed - only things that went wrong were weather related ie sudden squall ripping a jib to shreds. I just maintained that work horse of a production boat and I suppose luck played a part. Sailed her hard for 5 years, sold her to raise a family on land. Now I'm ready to buy again and I just don't want to deal with head and plumbing problems. I just dread it. I think I'd rather use a bucket with lehman's composting gel and dump it in the holding tank.
sailingmum is offline
post #13 of 20 Old 06-08-2009 Thread Starter
jarcher's Avatar
Let us know how that works out for you.
jarcher is offline
post #14 of 20 Old 06-08-2009
Courtney the Dancer
jrd22's Avatar
Just pump several times prior to using it, the bowl will be wet and "stuff" won't stick to it (usually). We've had one for years and it works great.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is online now
post #15 of 20 Old 06-08-2009
ever hear
ever hear of sarcasm ?
and I will. Thanks...
post #16 of 20 Old 06-09-2009
[B]pre-filling the bowl by pouring a little water into the bowl is probably a good idea before using it for solid waste...since it will allow the head to flush more cleanly...
Yup, I've been on a few boats that would not fill the bowl with the switch in 'flush or fill' mode. Used the hand held shower head to wet the bowl, switch to 'dry' afterwards and pump. Use additional water from the shower head as needed to completely clear the bowl. Although quite capable, I've never clogged one yet!
fullkeel7 is offline
post #17 of 20 Old 06-09-2009
S/V Loon
TaylorC's Avatar
Use a toilet brush
We keep a toilet brush next to each head, wedged back behind the hoses so it stays next to the head. I expect my crew to use it when they engage the head for something serious. Why should either the skipper, or worse still the first mate have to clean toilets on the boat?
Neither my newly rebuilt Groco type K or my Ratitan PHII (with newly replaced pump) fills more than an inch or so. These are double acting pumps, they draw water in on one stroke, evacuate waste on the other stroke, and the dry/flush value just controls it raw water is allowed into the bowl.
TaylorC is offline
post #18 of 20 Old 06-10-2009
christyleigh's Avatar
If the bowl does not fill, I can't see how these things don't get, you know, stuck all over the bowl then stink like crazy...
About 10 years ago I heard on another list that bugs Don't Like "Lemon Fresh" JOY dish detergent so we use that for dishes. I also always keep a slightly diluted squeeze bottle in the head and before I sit down for some solid business I give the bowl a light coating to help move things along. I also always use the "dry" not "sea water" setting on the input and use either the shower flexible hose on previous boats or the same type hose that comes right out of my head sink apparently just for that purpose to wash down the "stuff" and keep the smelly dead sea water beasties out of the picture completely.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #19 of 20 Old 06-10-2009
By not filling the bowl using the flush or wet setting, you're likely to be damaging the seals in the raw water side of the pump.
sailingdog is offline
post #20 of 20 Old 06-11-2009
Then why the heck do they give you the option then ???????? Any way that's the way I've been doing it for 3 years on one boat, 6 years on another boat, and now I'm into my 4th year on this boat - With No Problems. So I and many other people I know will continue to not use sea water to flush with and I'm not the Slightest Bit Worried about any problems you may have imagined.
Stan
'Christy Leigh'
NC 331
Fill in through-hull? pvemp Gear & Maintenance 4 05-15-2009 07:38 AM
discolered primary fuel bowl davidpm Gear & Maintenance 5 06-09-2008 09:02 PM
Outstanding fill cap design - but where? DanaDragoon Gear & Maintenance 18 01-09-2008 02:44 PM
Fill that hole GoodOldBoat Good Old Boat 0 07-23-2007 09:54 AM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
