06-07-2009
If you have access to both sides, a double sided repair with a 12:1 bevel will make a repair that is as strong as the original laminate or very nearly so, especially if you're using EPOXY resin, which has a higher tensile strength than Polyester or vinylester resins, and a very high secondary (adhesive) bonding strength.
Merely plugging the through hull leaves you vulnerable if the brozne dezincifies, and requires you to do constant inspection of the through-hull to check for dezincification.
