Old 06-07-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
What next? Epoxy done, what next under rub rail?
I've faired the aft part of our boat where the rub rail goes, with West Systems epoxy. What do I need to put down next?
The strip of new epoxy is wider than the rub rail (on purpose, there were tiny blisters from the water that gets trapped at the top of the rub rail).
So I need something that will protect it from the sun, and that will hold the 4200 that I'm going to use to glue the rub rail back in place.
Someone mentioned paint, could I use gel coat? What are my options? What would you do?
Here's the "before" picture from this thread (http://www.sailnet.com/forums/gear-m...waterline.html).
Here's some much newer pictures.
This one is a bit out of focus.
Old 06-07-2009
tager's Avatar
tager is on a distinguished road
Is the rubrail necessary?
Old 06-08-2009
scottyt is on a distinguished road
yes you can use gel coat, just dewax before you put it on. infact using the gel coat over the epoxy before the 4200 is a great idea, if you have to pull the rub rail the gel coat might be weak link and let the epoxy stay on the hull
Old 06-08-2009
Yes, you can use gelcoat over epoxy. West Systems actually did some testing of this... PDF
De-waxing the epoxy, especially if you used an epoxy with an amine blush, like West Systems, is very important. Sanding the epoxy lightly with a fairly fine grade of sandpaper to give it some "tooth" for the gelcoat to bond to might be a wise idea as well.
Old 06-08-2009
Bene505's Avatar
Is that what you'd do? I truly don't know what the plusses and minuses are of the various options available (gel coat, paint, what else?)
I did use west systems epoxy and I've already sanded it thoroughly. The surface is now "powdery" in a ppearance. Do I still need to de-wax?
(Oh and I have it under blue tape now to keep the sun (mainly) and rain off it.)
Old 06-08-2009
Personally, I would use Interprotect 2000E, not gelcoat... Paint is not an option for something that is that under the water IMHO.
Old 06-12-2009
Bene505's Avatar
I just called Ward at Beneteau and we talked about this project. He recommended using gelcoat.
That said, I may use a tad bit of Interprotect 2000e in the lower spots that get wet.
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Replacing a plastic rub rail. Northbeach Gear & Maintenance 2 04-25-2008 02:01 AM
O'Day 30 Rub Rail sailsdd O'Day 3 08-27-2007 01:20 PM
Pearson 36-2 rub rail damage Paysay Gear & Maintenance 3 07-12-2007 07:56 PM
Toe Rail And Rub Rail C&c FRANK PALERMO General Discussion (sailing related) 1 10-08-2006 09:14 PM
