06-08-2009
Is it a hatch or a port??? Hatches are generally larger, with an aluminum frame, mounted horizontally and open. Ports are generally smaller and may be framed in bronze, plastic, aluminum or stainless steel and mounted vertically, and not all open. Some ports, usually deadlights, are unframed and do not open.
