06-10-2009
epoxy to fiberglass question?
I think I found a reasonable and safe location to mount my Raymarine Autopilot computer box, at the aft end and at the top of the port aft berth. It is above where someone might kick it, while sleeping, and yet it is easy to get to if you crawl in head first.
Way to the aft, left of that opening port there is another flat vertical surface like the one up front on the left.
From what I have read here I should attach a wood strip to the fiberglass which is the inside wall of the cockpit and screw into that to mount the computer box. I have some 1/2 inch marine plywood that I will cut to a 2 inch width and notch to fit the slight curve shape of that wall. My question is what should I use to attach it to the painted fiberglass?
I searched this forum and I did find someone yelling about not using 3M 5200 ever and almost never use the 4200. My thought is that this might be the one time either it or the fast cure 3M 4200 might be the right material to use. Does that sound OK or are their better suggestions? I don't imagine having to remove this (as far out of the way it is) even if I remove the computer at some point.
cheers,
