Is my old thru-hull thru? - Page 2 - SailNet Community
post #11 of 19 Old 06-11-2009
moderate?
camaraderie's Avatar
Pix would really help...inside and outside if possible.
camaraderie is offline
post #12 of 19 Old 06-11-2009 Thread Starter
Skipper Joe's Avatar
Here are the measurements.
Flush mount.
inside dia: 1 1/2"
thread dia: 1 5/8"
(no surprises there)
Flange dia: 2 7/16"
flange height: roughly 2/8"
roughly 2/8" on the 45 degree flush angle
again with the 2/8" from the 45 angle to the pipe.
hell, does that make sense? I am so ready to be in the know.
Cheers!
Skipper Joe
Skipper Joe is offline
post #13 of 19 Old 06-11-2009 Thread Starter
pics
thanks in advance for the glance.
Cheers!
Skipper Joe
post #14 of 19 Old 06-11-2009 Thread Starter
fuzzy
Cheers!
Skipper Joe
post #15 of 19 Old 06-12-2009 Thread Starter
So I keep searching and searching but, no go with matching measurements.
my hull is countersunk to 2 1/2" but all the flush thru-hulls out there have a 2 7/8" flange. Does there exist in the universe a counter sinking tool designed to expand my mounting holes to a sweet 45 degree angle? Google is failing me. I'm tired of living on the hard. help me!.
Sounds like an Aerosmith song. "Living on the hard"
Cheers!
Skipper Joe
post #16 of 19 Old 06-12-2009
Swansea, MA
pfatyol's Avatar
Gil,
Why not use a router with a ball bearing - 45 degree chamfer bit? It may not be perfect since you have to follow the hull, but it will be pretty close.
If you wanted it perfect you have to make a templet for the router out of a peice of plywood, shim and hot glue it the hull - making it perpendicular and centered to the hole.
Patrick
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
pfatyol is offline
post #17 of 19 Old 06-12-2009 Thread Starter
Hey thanks Patrick. Good idea!
Cheers!
Skipper Joe
post #18 of 19 Old 06-12-2009
Maine Sail's Avatar
Clean
Gil,
Clean the old ones up with a brass wheel on a drill or grinder. If there are no pink spots and they are a traditional bronze color re-use them..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #19 of 19 Old 06-12-2009
moderate?
Gil...if none of that works out, you could build out with an epoxy slurry and fair to the hull, then mount any comparable standard mushroom head on there, or re-bevel to a different flush mount.
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 304 04-20-2017 07:58 PM
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 03:54 PM
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 05-05-2012 06:02 AM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
