06-10-2009
Autohelm Wiring
I am installing a Raymarine S1 Smartpilot and need some help with a couple of wiring issues.
The Raymarine manual says to "Use flat tinned copper braid, 30 A rating (¼ “) or greater" as an earth strap to ground the computer - in my case directly to the negative pole of the battery. My local electronics store seems to know nothing about selling flat tinned copper braid, although they seem to stock just about everything else electronic. Is flat braid critical for this RF ground or would an equivalent stranded wire (min 4mm diam - 12AWG) be perfectly adequate?
The manual also warns about using only Raymarine supplied ferrites for suppression purposes, but does not make it clear if any ferrites are needed on the power supply cable. Comments?
