help unstepping mast in MA - Page 2 - SailNet Community
post #11 of 17 Old 06-11-2009 Thread Starter
BristolJonny's Avatar
sweet, thanks for the link! That is basically the same setup that the Alberg site uses, except theirs is built with scaffolding pipe. I think i'll build one going the steel route for strength and ease of disassembly I just looked it up and my mast is 31'9". I think it is very similar to the catalina 27 so the dimensions should be close enough. I'm still wiched nervous to do it myself though! If anyone wants to come see the possible carnage one of these weekends let me know!
BristolJonny is offline
post #12 of 17 Old 06-11-2009
AdamLein's Avatar
One thing to note is that the A-frame is designed so that the noose that goes around the mast is positioned very close to the mast's center of gravity when the noose is a foot below the top of the frame. Since your mast is about 3 feet shorter, you'll want to keep the noose about 1.5 feet lower.
As for using pipe instead of wood, that's a pretty good idea. We have a lumber yard / hardware store right by the marina, and wood seems a bit easier to work with, otherwise I'd go with pipe. I'd still like mine to be disassemblable of course.
I'd love to come and help out with your unstepping, but, continents being what they are...
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 17 Old 06-11-2009
if you're doing this next weekend, let me know, I might be able to help...
sailingdog is offline
post #14 of 17 Old 06-11-2009
jarcher's Avatar
That's only about a 45 minute ride for me. I have never done a mast unstepping (other then for a dinghy) but I'm willing to come help to see how it's done, provided I'm available that day. I need to do mine soon (or have it done) so it's a good opportunity.
jarcher is offline
post #15 of 17 Old 06-11-2009 Thread Starter
well I guess I'll have to get one of these things built!!!
post #16 of 17 Old 04-09-2013
Re: help unstepping mast in MA
Hi BristolJonny, here is a thought even if it sounds unappetizing. You are under time constraints to move your household, your boat and yourself to a new job. Sometimes cutting your losses is best if it will take stress off you.
I would have the boat yard unstep it even though it costs $200. When you get settled in, buy the materials for an A-frame and get an old seadog to show you how to use it on someone else's boat who is hauling his boat for a bottom job or something.
Next time you need to put it up or down you will be in A-1 shape. Just a thought.
Fair Winds is offline
post #17 of 17 Old 04-09-2013
blutoyz's Avatar
I was just thinking the same thing. You have spent and will spend $200 on much less deserving things in your life I am sure.
Just my $.02
blutoyz is offline
Southern Cross 31? db27513 Boat Review and Purchase Forum 36 09-02-2016 12:48 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 08:55 PM
Mast types...? Through deck on deck...? marinesniper General Discussion (sailing related) 41 02-02-2007 10:15 AM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
