06-12-2009
Iroquois MkII
filling holes in deck - what tape to use on bottom?
OK one last goofy easy question that probably everyone knows the answer to.
When I'm filling a hole in the deck (e.g. overdrilling, fill, then drill smaller hole, so no core is exposed), I'm supposed to tape from the underside, and then fill with thickened epoxy, let it cure, sand it flat, and drill the smaller hole through the middle. Easy enough.
But what kind of tape do I use on the underside of the hole, so that the thickened epoxy doesn't stick to the tape itself?
