Swinging Dinghy in Davits - Page 3 - SailNet Community
post #21 of 25 Old 06-16-2009 Thread Starter
I cross from East Greenwich, RI to Newport and a couple times a year out to Nantucket and MVY. If I was to do a crossing, which I doubt I ever will I would have the dink stowed for sure. I spent 3 months in the Bering Sea and know what seas can do. Davits are great for coastal stuff. Il;ove having them
recycle is offline
post #22 of 25 Old 01-31-2011
Recycle: this is an old thread. I'll post here and try a pm.
I have a Tartan 3800 and am looking for advice on installing davits. Any thoughts would be much appreciated.
Thanks.
wilsonlb is offline
post #23 of 25 Old 01-31-2011
Wilson--
You'd be much better off starting your own thread on installing davits, since that is NOT THE TOPIC of this thread. I'd also highly recommend you read the POST in my signature.
sailingdog is offline
post #24 of 25 Old 01-31-2011
tomhuntdmd's Avatar
Tie downs
We use these 20' gunwale tie downs from West Marine:
INDIANA MARINE Tiedown at West Marine
They are heavy duty SS and have a nice set of hooks. Just throw the long end over the dingy, grab from undernieth with a boathook, clip on the other half, and tighten the ratchet. Very sucure if you use two. I don't sail with the outboard attached. Too heavy when heeled way over.
tomhuntdmd is offline
post #25 of 25 Old 02-01-2011
I sail a Hunter 44 DS with the Hunter davits and use these straps also. I supplement those with several criss cross lines from hard points on my 10'-6" AB with 15 hp engine to the davits themselves. A couple years back I added a SS strut from the davit to a hard point on the dinghy transom. All-in-all a very snug and rigid lash up. It takes about 15 minutes to hoist and about 3 minutes to launch. With the Hunter davits so high above the water I don't worry about being pooped, and I have no plans to cross the atlantic. the dinghy doesn't move, squeak, or swing at all.
Rick486 is offline
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-11-2004 08:00 PM
Choosing a Dinghy Sue & Larry Gear and Maintenance Articles 0 10-09-1998 08:00 PM
